Interior lights stay on
I hope someone can help because I cant figure it out.
Everything was fine, the car sat for one week with the trickle charge hooked up. when I tried to start it the battery was completely gone... down to 6 volts.
So I figured a cell went bad or something and changed the battery, car started up fine but when I started driving I noticed my interior lights were on. So I thought that must have been the problem that killed my first battery, but no! the dimmer switch near the headlights was about in the middle brightness setting and works fine. I cant get the interior lights to turn off??
2002 SS with lots of mods
Normally when I lock the car with the remote it turns off the lights inside. That doesn't work.
Also after 10 minutes the car normally shuts down and turns off everything. That doesn't work either!
Save the manuals!
Gotta ask - Have you checked the dial that controls the dimming of the cluster lights to make sure it isn't to the position where it turns on the interior lights? If so, I'd check again.
If that isn't it, put the key in the ignition (car off) and open the door to check the door sensor. You should get a chime if its working correctly.
Well this just got even more strange. I was going to just look at some wires or see if I could find the problem yesterday, when I got out to the car everything worked fine!
So I jumped in and went for a drive, thats when my drivers side power window stopped working halfway down.... I started cursing and drove it home. When I got home it was working again!
I dont know much about wiring and electronics, but is this a lose connection or a bundle of wires shorting out? any ideas where I should start looking would be helpful. Thanks for your time
The dimmer switch worked dimming the guages, but it wouldnt turn off the interior lights when I had the problem. I didnt think to check the key chime at the time.
Im going to follow every wire I can this weekend and let you guys know if I find anything.
Hey i was just wondering if you ever got this figured out? When i got my car all the dome lights were unhooked and i soon discovered when you hook them up they never go off, I checked and they get a constant ground from the bcm even when i disconnect all door and hatch sensors it never fades the ground out. At the moment i bent the ground prong on the bcm out of the way so i can just use the mirror lights by switch. I'm looking at some used bcm's on ebay just wondering if thats what it took to fix yours.
