my car hates the cold
Old 11-13-2013, 05:32 PM
thatguy1559's Avatar
Default my car hates the cold
last night was the first night temps drop to around 26. and i start my car to leave work and after a min or two of letting it warm up the SES light comes on. seemed to run fine so i drove it home and it was all good. I went to get the codes checked turns out it was 10 of them. All heated o2 sensor failed. MAF sensor voltage circuit, 4 injector coils codes, and injector circuit voltage high. And the radiator cracked all this happened at one time so what would cause all the codes.
Old 11-15-2013, 09:36 AM
NC01TA's Avatar
Your title probably tells it all. Too cold. It is probably affecting the readings. If those issues are not happening when the car is warm (no SES light) then you are probably fine. If you don't like seeing that happen all winter I'm sure a competent mechanic can 'fix' the false readings. I sure would.
Old 11-15-2013, 11:37 AM
ramairetransam's Avatar
fix the issues you can the car should run fine with the cold. My formula has been loving the cold air in the mornings. about 26 this am .
Old 11-15-2013, 11:48 AM
KissMyTushZ28's Avatar
It was 26 degrees for 2 nights in a row and my T/A loved it! Had some cool backfire going on during decel.
Old 11-16-2013, 06:03 PM
dailydriver's Avatar
^^^ 26* in the Hill Country?!?!
WHAT is the record there for this time of year??
Old 11-18-2013, 05:10 AM
Weird thing was I changed the radiator and while I had the bellow and stuff off I looked through the maf and it had residue all in it couldn't really tell what it was but I just cleaned it with some spray check engineklight when off and seem to run better. So i'm assuming when the radiator bust coolant got sucked into it and caused the light.
Old 11-18-2013, 05:11 AM
The record low here I think was 14 if i'm not mistaken from what the news said.
Old 11-18-2013, 12:55 PM
2 years ago on thanksgiving it was below 20 real-feel here! It was about mid 30s with a ridiculous skin tearing wind! It sucked! Then it was in the 80s a week later....
Quick Reply: my car hates the cold
