Power steering cooler delete
I'm just trying to figure out if the previous owner did me the favors of deleting the factory cooler for me I believe he did there is one long hose going from the water pump to the top drivers of the radiator as there should be also it appears that there were 2 small hoses coming off of the larger hose that have been plumbed in together does this sound like a delete to you guys
If so, then he stopped power steering fluid from going through that cooler pipe, so I guess you could call that a delete. If I were you I would go spend the $15.00 or so and put a rubber hose on. All rubber upper radiator hose. That metal pipe is ugly.
Then spend about another $25.00 and put an aftermarket 4 rail cooler on there. Takes 15 minutes to put it on. Your power steering pump will last a VERY long time. Mine is 15 years old.....they die from heat. Keep them cool.
Yea, ditch that metal pipe as it could still fail and than you will loose your radiator fluid out of those two holes. An aftermarket one is the way to go. I have a 2 rail one right behind the air damn on my front bumper, but mine is 24" long, so it keeps my fluid nice and cool. Much happier and the steering feel is 10 times better, at all temps.
See mine in here:
https://ls1tech.com/forums/general-m...g+fluid+cooler
......and NO, the slit has absolutely ZERO affect on coolant temps......
Or, IF you live where it gets cold, and HAVE TO use this car year 'round, since it is your ONLY vehicle (like me, but unlike almost everyone else on here), you could add a cooler, and put a thermostat on it, or just run VERY VERY thin fluid in the winter.
LS1Tech Administrator
Received 1,492 Likes
https://ls1tech.com/forums/general-m...g-success.html
Depending on your driving style and climate, an aftermarket cooler may not be necessary and, you may be better off with no cooler at all than with the factory cooler. In any event, it's best to remove the factory cooler before it begins to leak IMO.
Well that was my original question I guess it has been deleted as far as functionality but it's still their I will put a cooler on eventually however I drive the car maybe once a month
Both myself and "RPM WS6" have had incredibly long lasting parts on our cars. Like I mentioned, my power steering pump is factory original and 15 years old now. I know its because of how cool its been running, because I have way over 200,000 miles on my car....hard *** life of driving in South Florida heat. I like to keep things cool as possible. My car has been my daily driver since 1998 when I bout it new.....so it's used a LOT......which is a good thing for car parts.
......although, my girlfriend went to start my car yesterday to let it run for about 10 minutes.....and the damn battery was too low to start it. I've been out of the country working for 5 weeks.....and she waited too long to run it......women.....!
As far as the PS cooler goes, I agree that you definitely need to take your respective climate into account. It's so rarely hot here in Chicago that, as my tests showed, PS fluid heat isn't a huge concern under normal daily driving conditions in our normal summer weather. I'm sure south FL is a different story, so again I encourage individuals to consider their climate AND driving styles when deciding whether or not a cooler is needed for their application.
Back on topic, when i was in San Diego, my non cooled PS Pump that i ran after deleting my stock one killed my original PS Pump, but i drove it every day with stock 275's up front. Did that for about 3 years till i went with an aftermarket cooler and could not be happier. But down there it was really hot, up in WA, i have to give it a few lock to lock turns so it is not so stiff in the winter. Really depends on where you live, but mine is not a DD any more.
After several tests and review of the data, this was the conclusion I came to as well. All of my results were posted in the latter pages of this thread:
BUT, in ANY case (with OR without a cooler), I DO advocate for running a very good, high VI index, synthetic power steering FLUID.
