Turn one steering pump: does it need a cooler?
I've been poking through, and read some of the sticky, regarding the power steering cooler and the headaches it's causing. (What happens? The cooler cracks and leaks fluid into the block?).
While I think the factory design seems like a good idea, the worry of having to flush my cooling system scares me from reusing the factory cooler.
I think I need a new power steering pump anyways (mechanical whine when the rpm's rise, and I'm in a turn), and I was wondering if you can forgo any coolers with the TurnOne pump?
I have sticky 275 wide tires on the front, but I don't see myself entering any road course events in the near future.
Would a more efficient turn one system be okay without a cooler?
the oem power steering cooler really isn't a cooler- it's in the upper radiator hose so it will actually heat the power steering fluid and keep it around 190°F. i suppose this was done for fuel economy reasons, hotter power steering fluid = lower viscosity = less power loss by power steering pump.
I would just undo the power steering hoses to the oem cooler, and connect those hoses together thus bypassing the oem cooler and running without. there are reports in that power steering cooler thread about fluid temps in the reservoir well less than 200° running with no cooler. i would say ideal temps are 120-180°F. you can pick up a digital thermometer from walmart for less than $10 that you can stick in the power steering reservoir and check fluid temp, run with no cooler and check it after driving on a hot day. if you're running over 200° in the reservoir then consider adding an aftermarket cooler.
LS1Tech Administrator
Received 1,492 Likes
Unless you are using the car for competition purposes, or live in a very hot climate, I don't really see a need for any cooler (stock or aftermarket) based on my own personal testing and experiences (details contained in PS sticky) - even with the stock pump.
Furthermore, the Turn One pump has been tested to run cooler than stock pumps so you should see some fluid temp reduction just by switching to this pump without any other changes.
If you're willing to change the PS fluid once in a while, you probably wouldn't need a cooler even in a hot climate.
I have a Turn One pump AND an aftermarket, stacked plate, air to fluid cooler in the return line (with NO thermostat to control the temps).
It actually runs TOO COLD in the winter (daily use/ALL conditions car) to the point that this past brutal winter, I actually had to change to the SUPER thin, crazy high viscosity index, Pentosin CHF 11S fluid in order to keep the pump from complaining (due to way too cold/viscous fluid) in the sub 10*F ambient temps we were getting on a regular basis!!!
So take that into consideration if you feel compelled to install an efficient cooler with the Turn One pump.
Save the manuals!
I still have nightmares from driving a rental van through downtown Boston but I recall that there are a lot of turns in the roads outside the city, as well. I'm sure the extra effort for the TurnOne enhanced pump isn't a big deal, but I'd think it would get tiring for a lot of daily driving.
I had my pump rebuilt by TurnOne and they did it to stock specs for me, since I do a lot of downtown city driving. It's been great, seems to be high quality, and I was able to have them put their pulley on the unit.
I walked in to that one. This actually was a big issue for me when I rebuilt my pump I had a torn labrum in my shoulder. I got that fixed, too and now I'm strong - like bull.
The increase in steering effort is less than swapping in a 25% UD pulley, and its only at very low speeds. Anything over 5mph feels the same to me. Of course I cant tell at all anymore, that was a long time ago when I first put mine on.
Same here, in fact, I did not even notice any more effort AT ALL, even with a 330 mm diameter (< 13" diameter) Sparco aftermarket wheel.
