looking for a direct replacement radiator for my 02 ss camaro
Old 06-20-2014, 05:11 PM
meatyz's Avatar
Default looking for a direct replacement radiator for my 02 ss camaro
i got a hole in my radiator today in my 02 ss its a uto cam only makeing 430rwhp after researching i see some people use a lt1 radiator question i have is it direct replacement same brackets the condenser sits in and all? and i also see theres a thicker lt1 radiator for better cooling where should i look for these?thanks guys
Old 06-20-2014, 05:49 PM
meatyz's Avatar
tomorrow i will try advanced auto do you guys no if theres a certain part number for the thicker radiator?
Old 06-20-2014, 06:30 PM
Empatho's Avatar
Just ask for a radiator for a 94 z28 and when you get it make sure its thicker then the one you have.
Old 06-20-2014, 08:50 PM
Moderator
jimmyblue's Avatar
It fits up directly, you just have to block off some unused
ports.
I think I saw, not that long ago, someone saying they saw
(or had) a LT1 thick core with LS1 end tanks. That would
be ideal. But I forget who/where, now.
Old 06-20-2014, 10:05 PM
meatyz's Avatar
ports.
how many unused ports we talkin about?
Old 06-21-2014, 03:12 AM
LS6427's Avatar
One port.....and again, it makes a great flush drain.
Here's mine....you can see my 6 inch piece of heater hose as my new fast drain port.
https://ls1tech.com/forums/attachmen...r-dsc01789.jpg
Old 01-19-2016, 07:47 PM
LeadfootDuramax's Avatar
I am going to replace the radiator in my 02 Z28 in the next couple of days. The parts places show the LT1 radiator as the replacement even though its got the extra hose connection. They list 2. One that is a "cradle mount" and one that is a "saddle mount". Which one is correct? I am just trying to make sure I have the right one available so I can limit my downtime.
Old 01-20-2016, 05:49 PM
Latch's Avatar
Originally Posted by the crowing
when i replaced mine i went with this one here https://ls1tech.com/forums/generatio...-radiator.html
Same. Direct drop-in replacement and significantly thicker.
Old 01-21-2016, 08:13 AM
farmington's Avatar
A bigger more efficient radiator may cool better but also might cost you some horsepower. If you didn't have any overheating issues with the original radiator, replace it with the same part. It will add some weight to the nose of the car with the weight of the rad and the extra coolant inside. Now if you lived in AZ or something it might be a good idea.
Cooler does not always mean more HP and could possibly mean less.
Old 01-22-2016, 03:20 PM
HappySalesman's Avatar
What farmington said. Remember, the coolant temp of your car is mostly regulated by the thermostat. As the coolant cools, the thermostat closes a bit and restricts coolant flow. So if you have no overheating issues with a stock rad, go with that.
Old 02-12-2016, 01:16 AM
bigsticksupra's Avatar
LT1 radiators have a low coolant sensor. you need to get the sensor to plug the hole. also the extra port on the driverside that needs to be blocked as shown in the post above.
i used an LT1 radiator in my 00 SS that i plan on road racing. I just got a generic vistapro radiator and the core was much thicker than my stock one
Old 03-21-2016, 11:08 PM
johnp94's Avatar
Anyone have the Answer to what the other member asked. Cradle mount or saddle mount ?
Quick Reply: looking for a direct replacement radiator for my 02 ss camaro
