wondering if it is worth it to keep my Camaro
I've got an 02 Camaro SS (auto) that has been the biggest pain in the *** to fix. My parents let the car sit for at least 5 years and now they finally let me (attempt to) fix it for myself. Car wouldnt start. Took it into the shop and they got a new fuel pump, changed spark plugs, air filter, gas filter, trany flush, etc. Just a major tune up. Got it back and went to get it smogged. Didnt pass because of new battery. Took it driving then it overheated. Took it back to the shop. They said coolant temperature sensor. Changed it out, got it back. Took it driving to reset it because of the new battery so it could pass smog. While on the freeway, lost all power. No brakes, no acceleration. Got it towed back to my house and ran my obd to it. Got the codes P0758 (Shift Solenoid B Electrical) and P0102 (Mass or Volume Air Flow Circuit Low Input). As of now the car won't turn over. Crank but won't start. Id appreciate any help or suggestions.
Location: Illinois, as close to "Normal" as I can get...
Also look for rodent damage on the wiring harnesses throughout the car, if it sat that long some mice might have made it their new home.
i would bet on a thermostat causing the overheat, and not the sender. I'd be careful going to that shop they might be taking you for a ride on parts.
how does a new battery cause it to fail emissions ?
it would be your diagnostic trouble codes (DTC's) that caused the failure.
And yeah man, you will go broke way before you ever get this thing running if you don't do most of the work yourself.
i would pull your underhood fuse boxes apart and look underneath for signs of rodents.
A new battery causes it to fail emissions because it clears all your codes. You need to drive 30 miles (or maybe it's 60) before the computer resets everything. When they scan your codes they can tell if your codes have just been cleared, which is why you can't just clear your codes 10 minutes before you get your emissions testing done....
