Window Problems
Window Problems
My drivers window will go up and down, but will not go all the way up. If I do manage to get it all the way up, it doesn't want to stay up. Closing the drivers door is amusing to watch. Passenger window will go down, but will not go back up.
We've decided to replace the window regulator and motor on both doors, does anyone have some tips or a step by step guide on how to do that? I'm assuming it's not terribly difficult.
Save the manuals!
https://ls1tech.com/forums/general-m...-included.html
Please post pictures or videos of your problem, which will help us. You should take the door panel off ASAP to confirm what your status is. The more you use the window, the worse this problem will get.
2) This is a classic thermal cutoff failure of the motor. (It could also be a switch problem - but a bad motor is most likely.
If it is your motor, you'll want to lookup the shbox replacement method and do that instead of removing the regulator. This will help you avoid the problem you already have on the driver's side. (Your driver's side regulator was probably removed in the past and not re-attached with the required rivets.)
3) A chorus of Autotrix fans will chime in her shortly telling you that you need that kit to "fix" your passenger side problem. You can pass on that - it's snake oil.
Out of town at the moment. I'll get some pictures and a video of the drivers window when I get back. I'll avoid the passenger window for now as it is a complete pain in the *** to get it back up.
Save the manuals!
Not using the window is the best thing. If you need to get it up in the meantime, you can open the door and tug up on the glass while you try to operate it. The extra "help" against gravity and lack of weatherstripping to rub up against may keep it from tripping out on you as much.
I should have a video in a day or so.
I've dug through a few threads now...really not looking forward to the drivers side window. Passenger's side doesn't seem too bad, but the drivers side...ugh.
Window problems are no fun
Food for thought... While you're in there, I would replace the window motors as well. They will go bad at some point, and are pretty cheap, so think about just replacing while you're already in there.
Check out the Dorman 742-101, that's the best one out there.
Last edited by meeklay812; 02-08-2015 at 08:06 PM. Reason: non-sponsor advertising
I'm going to let my buddies dad take care of it. In the process, I'm going to replace both motors especially seeing as how the passenger motor is bad as well as the switches on both doors. Should eliminate any possbility of future problems. Will also probably have him fab up metal plate for both doors to future proof it even more so there will be no chance of the rivet holes failing again. Should be fun...right? lol
So...just to be clear before I go buying parts... I need...
-Window regulator (and go ahead and replace the motor) and custom fix for drivers door
-Window motor for passengers door to fix thermal cut off
Money is tight at the moment so I just want to be sure of what I need...
Unfortunately the power window motors are a weak point on our beloved F bodys.I learned a long time ago, spend the money on a good brand name motor(window). I went through three Ebay ones!!!. CRAPOLA $0.02
Save the manuals!
Check <non-sponsor name removed> for the Dorman 742-101, thats the best one and I think its like <non-sponsor price removed>.
Sounds like a solid plan! Dormans motors are 36 bucks a piece through the local O'Reilly's and a set of new switches is about 40 bucks. My friends dad has been working on f-bodys since the early 3G's, so he probably has an understanding of my problem. I'll keep you guys posted with any further videos/pictures as well as if I get my issue fixed.
Big thanks.
Big thanks.
Save the manuals!
If he's been doing it right all these years and following the factory install instructions, then he would have never seen this problem by his own hand and may not be familiar with the shbox motor install method.
I'd still print out the plate thread AND the shbox motor install thread and take them to him.
