adding fuel takes 30 min??
when i put gas in it takes about 20 to 30 min its a 99 ls1. i removed the rollover valve in the neck thinking that might be stuck but nope it still does it any idea WTF is stoping the gas from going in.i can only put it in really slow if i pull the gas trigger at full the gas sprays back out thanks for any input
When it happened to someone I know it was a pinched filler tube to the tank. Have you had the tank dropped for a fuel pump or anything that could have something pinched when it was put back?
Does it do that at every pump? I've noticed Exxon pumps give me weird problems. It will keep kicking off like the tank is full, even after only a couple of gallons. I have to stand there and hold it the whole time. No other gas stations seem to do that, just the Exxon pumps. I pretty much only use BP now, or Shell in a pinch.
Make sure no onw put anything in there! You try other pumps?
I am a claims adjuster and i had a claim once that someone put a tampon down in her tank!!
Was a pretty funny claim to talk about to say the least!
