missed shift=hissing?
i was flogging the car tonite and did a wot 2-1 shift, ouch. car idled fine, no ticks, knocks or taps coming from the engine, but i did notice a light hissing sound on the drive home. I popped the hood and there was a pretty nice hiss coming from somewhere around the back of the intake. Is it possible for a misshift to pop a line off, or is this a complete coincidence. I'll find it and fix it, but i've never heard of anything like this happening. Any suggestions?
I was going to say maybe the intake hose/bellows came loose but you said the back of the manifold. There is a vacuum port on the back though, maybe its a bad connection.
The hissing noise you are hearing is probably a vacuum line that blew off from the mis-shift. See if you can locate where the hissing is coming from exactly, and it should point you straight to the detatched line
Originally Posted by Domestic Demon
What RPM were you are when you mis-shifted back to 1st gear?? If you were at the redline in 2nd, its almost a definite that something is damaged in the engine. Pushrod engines just can't take those kind of high RPM's.
Originally Posted by Sgt. Spuds
Get a short throw shifter before you try this again
Originally Posted by 98camaroLS1M6
Do you think you have bent pushrods? I did the same thing but the car felt perfectly fine after. If bent pushrods are the case, how much power is missing?
if your pushrod was bent, you would be hearing all kinds of ticking and stuff
