Screach when I turn?
Shirley Temple Drinker
WTF? You can hear it in this video when I go around the first corner, it makes a squeak squeak squeak sound as I go around a corner, weird and annoying
http://video.ls1tech.com/video/2D09A...0808924239.htm
are hub bearings hard to replace ( ****, IDK what that is lol ) and are they expensive? If they are only like fifty and not hard to replace i'd be willing to do that...
How about the power steering pulley? That's where you might also want to look if it only does it when you turn. That is, if it does it when you turn both ways. If it only does it when you make right turns, it could be something else (bearings). I have 96K on mine and never changed the front bearings, no noise. (I know probably should change them anyways though.)
Is it only when you turn right? Does it only happen when you hit the brakes? Were you hard on the brakes right after you put them on? If you beat up the new brake before they had a chance to break in the could be squeaking from that. If your not too far away from me, i could look at it for you.
Originally Posted by Joey7489
it really does sound like a wear indicator on the pads, did you grease em before you put them on?
I had a 96 RS. When making a u-turn to the left,it made a scraping noise. Turned out to be axle end play. The axle slides out enough that the rear caliper bracket hits the rotor. GMs fix is a bracket spacer. Put it on and the noise went away. Try it. JMHO.
