And then I noticed the little door.........
Saw that my right front turn signal/ parking light was out. Zipped into auto zone, picked up a new bulb and headed for home.
Popped open the hood and took a look.
Hmmmm.......
Tried to snake my big ss hand down thru the bracketry. Not a chance. Couldn't even touch the damn thing.
"This could be trickey", I said to myself.
Checked the time, still 6 hours of daylight left.
Just in case though, I brought out my portable light tree.
Took another look around.
Wondered which would be easier, pull the radiator and all the supporting bracketry, or jerk off the front clip.
"Better be ready for anything", I told myself.
Got out my air tool's, fired up the compressor, checked to make sure the ol' arc welder still worked.
Scratched my chin for a second. Went next door and borrowed my friend's cutting torch just in case I had to notch the frame for clearence.
Put on my coverall's, got my goggle's. Sat down by the right front tire and put on my boot's.
And then I noticed the little access door for changing said lamp.
Thank you dear lord.
Hmmmm.......
Originally Posted by jkichline
That is one good story man! If you've ever felt like you have to take the whole car apart to do the most simplest thing.... try owning a ford!
Items for discussion
1. Develop and share designs focused on thwarting every shade tree mechanic in the U.S.
2. Where to put the air cleaner? The benefits of locating an airbox between the block and the firewall.
3. Etc.
where is this mystery door??? mu light burnt out twice, so i jam my hand into the turn signal/parking lamp air damn/hold under neath it, and wrap my hand up into it. Like you have the turn signal, then below it is an opening in the front bumper, so i put my hand there. where is this door? take a picture tht would be clutch...
Near the edge of the bumper cover, directly under the foglamps are two 10mm bolts. Remove those and pull down on the outside edge of the flap. Be ready for junk to fall on your face.
arghhh... I just had to change mine out. So it's been like 3 weeks, I got the bulb the day I noticed it burned out. However, I searched on here to find out how easy/hard it was to do.. Notice, it was 3 weeks ago... So I tried this sunday, I went to work, 10 mm socket, check.. cheapy wrench from walmart, check, oops broken.. now i'm stuck. I just recently moved, and have no idea where most of my tools are, spend 35 mins looking for socket set... never find it, call friend, he comes over.. bolts rusted shut, go to store get PB blast, start again tomorrow. This is where I am, today, get out the pb blast, and shoot it, get the bolts off, open trick door, and get ready to pull out light bulb.. can't figure out what the heck to do. So I come back on here, find this thread and go.. hmmm, so then I crawl completely under the car, I sometimes have clousterphobia, not this time, because I'm mad and my arm is bleeding from going under the car and under the light assembly. I see oh, all i have to do is twist this way, I was looking for a tab release thing. After twisting with both hands finally comes free. Then 2 minutes later I'm good. So basically all in all, 3 weeks work really took only 5-10 minutes, plus I was doing all of this by myself with a flash light in one hand.. It would help to have jacked up the car.. Of course now, i have one orange bulb and one white one....for now... I think I'm going both white
The real fun begins when you try to put the bulb back in the housing and it falls out of the socket. It took me a half hour to fish it back out. I had to get real crafty since it slid over to the far end of the housing. I ended up pulling in and out of my parking spot, making the turn real hard to get it where I can get it to the tips of my fingers. It was fun, thanks G.M. . I guess it could have been worse, I could own a ford. Come to think of it I hated changing them in my 3rd gen bird too.
Hmmmm.......
Hmmmm.......
That was some GOOD **** there.....LMAO...
