what is the Check Gauges Light?
Old 08-29-2006, 03:20 PM
01Generalee's Avatar
Default what is the Check Gauges Light?
Mine sometimes flickers under full throtle conditions
Old 08-29-2006, 04:50 PM
2KThunder's Avatar
It means one of your gauges is where its not supposed to be. Like it will come one when your gas gauges get into red, your voltage is to low (or high) etc. So when you see it make a sweep of your gauges, and make sure nothing is in red.
Old 08-29-2006, 06:00 PM
Moderator
davered00ss's Avatar
What he said.
Old 08-29-2006, 08:14 PM
Transam295s's Avatar
If all of your gauges reads correctly which is possible. Then its quit possible that you have a bad ground wire, plug or wire. Mine flickerd under heavy load and turned out to be a bad spark plug that was acring to some wires. Couldnt see the arc but heard it. Just an option.
Old 08-29-2006, 08:31 PM
bww3588's Avatar
so the check gauges light acts as a low fuel light?
Old 08-29-2006, 09:12 PM
2KThunder's Avatar
It alerts you if ANY of the gauges are not reading what they should (assuming its working properly)
Old 08-29-2006, 09:35 PM
bww3588's Avatar
this i understand, sorry to *****, but what i was getting at was does it come on when your tank reaches a certain level like a normal "Low Fuel" light? or is it just an idiot light?
Old 08-29-2006, 10:47 PM
ssMoe's Avatar
Yes, Mine came on a few days ago when I was low on gas and went away when I filled up.
Old 08-31-2006, 09:48 AM
_JB_'s Avatar
Yes, when I bought my car the gas was low and that light was on. Only time I've ever seen it.
Old 08-31-2006, 11:39 AM
FirehawkNS's Avatar
You might have had low fuel and when you stomped it, the guage dropped and the light kinda flickered!!
Old 08-31-2006, 03:47 PM
Dal1as's Avatar
Mine does this every once in awhile and I've checked everything, no arcs, plugs are fine, no ground issues.
Old 08-31-2006, 10:35 PM
BigE's Avatar
Mine did it at high rpm's. Turned out that the engine-chassis ground wire was touching a wire bundle and the top of the alternator. I just unbolted it, ran it another way and replaced the bolt. I ran it such that it was not under a lot of tension and not laying on the alternator case. Problem solved.
Old 09-05-2006, 01:31 PM
Dal1as's Avatar
Awesome, that's probably my issue.
