car revs to 3000 on startup, then dies.
hey guys, just did the LS6 manifold swap along with !AIR and !EGR and now I'm having problems. The car sounds A LOT louder to, like it has an exhaust leak but I bought the blockoff plates for the !AIR and !EGR so this shouldn't be the problem. I also had the battery unplugged so maybe the PCM is trying to find idle? any ideas?
Go over and recheck everything, rough idle is normal while the PCM is relearning. You didn't mention a SES light, but some codes will not come on until after a few ignition cycles. Since you did !AIR and !EGR at the same time if they weren't already deleted you should be getting a light for those too.
I'm guessing vacuum leak too. Might be the intake gaskets not seated right. Brake booster hose not connected. PCV lines all connected right?
If it's louder you might have a exhaust leak. Did you put the gaskets back on with the block-off plates?
Also check for any sensor or hose that might not be plugged in.
