Motor Oil
Tech Resident
actually, the LS1 takes 5 1/2 quarts of oil. putting 6 quarts of oil in the LS1 is overfilling, unless you use the larger K&N truck filter that holds more oil. then 6 quarts can be used. in many cases, it could be worse to run too much oil than not enough. i know this holds true for transmissions, when the increase in pressure can actually do more damage than a small decrease in pressure.
It states 5 1/2 quarts with a filter change in the owners manual. Putting in more than about 5 3/4 quarts is definitely overkill, its not good for the motor to have too much oil in the crankcase.
