Break Pads
Break Pads
I have a 1998 z28 and I have not changed my pads since I have owned the car which is about 5 years now. The car still stops great. Just wondering if i am due for new ones or what is the sign that I need new ones. Thanks
LS1Tech Administrator
Received 1,492 Likes
You can't really go by age. My '98 has stock pads too, but it's very low mileage. If you do basically all highway driving, then even high mileage won't necessarily mean much.
For regular street use I like stock GM pads the best. Less dusting than most aftermarket pads.
well if there making a squiling sound is one way if your brake fluied seems low and you know you dont got a leak. or a good way is look up see what the thickness should be and measure them. or if the got cracks.
Originally Posted by Slammed99s10
Whatever you do don't replace them with any brake pads from AutoZone. Made that mistake, they squeal like hell and the dust is horrible.
Originally Posted by skifast87
did you use the anti squeak
As was said, pop the wheel off and take a look through the keyway to see how much pad you have left. If it has been a while, you could also pull the caliper off and check the pads for even wear. They should wear evenly not like this [/ or like this [\ if you are looking at them on edge.
