rpm's drop slooowww! on 02 WS6
Old 02-15-2007, 12:06 PM
garrett3's Avatar
Default rpm's drop slooowww! on 02 WS6
when I push in the clutch to shift the rpms don't drop unless I wait about 5 seconds, but the clutch is not doing anything else wierd like slipping under acceleration. It feels good besides this. Any suggestions?
Old 02-16-2007, 02:56 PM
_JB_'s Avatar
Maybe a vacum line has a crack or has come loose.
Old 02-16-2007, 03:08 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Sounds like a vacuum leak of some sort to me as well...
Old 02-16-2007, 09:12 PM
96slow6's Avatar
When is the last time you check your air filter?
Old 02-18-2007, 01:15 AM
fuseone's Avatar
well how quick should the rpms start droping because mine doesnt do it right way takes maybe a second or so but not no 5 seconds maybe 3 at the most
Old 03-02-2007, 01:49 PM
garrett3's Avatar
the air filter is clean. There doesn't seem to be any pattern to it, Ive had it happen when it was cold,hot,high rpms,low rpms, and it will only do it once or twice then nothing for a week or so. Actually kinda helps on fast shifts
Old 03-02-2007, 01:57 PM
99kamarokid's Avatar
im having the same problem, do a search on rpms lagging... i started that thread, and there are a few suggestions in there...
Old 03-02-2007, 02:07 PM
formuhawk99's Avatar
Same thing here. It seems to be worse when the engine is cold. When I really notice it however is after I have been driving at a sustained speed for a while. When I get off of the freeway it seems to take a while for the RPM's to drop down again. My car has a naw cam, heads, intake, headers, FIPK and the AIR and EGR removed. Does this sound like a tuning issue as well?
Old 03-03-2007, 05:45 PM
delsold's Avatar
I'd think a vacuum leak of some sort too. Or maybe your crank position sensor is bad, or going bad, but i'd think that'd be more likely to cause a no start than a rpm drop lag.
Old 03-03-2007, 10:30 PM
Blk97WS6's Avatar
Ive had that problem ever since i got my car tuned for the cam. Im currently trying to track the problem down.
Old 03-03-2007, 11:38 PM
MeentSS02's Avatar
Your problem could be in the tune...I can get my RPMs to hang if I mess with the tune enough.
Old 03-06-2007, 10:56 PM
sdm1234's Avatar
my RPMs hang too after a PCMforless tune. if anyone finds a problem, please update!
Old 03-07-2007, 08:37 AM
PCMFORLESS's Avatar
Typically this is caused by either an Idle air controller that is too low, meaning the throttle blades are open a bit too far or if you drilled the throttle body. Also a vacuum leak can do it. Also a TPS voltage a bit too high (.67 to .7 at idle works good) can do it as well. Also, there is an idle air decay table in the PCM that can be increased to try to get it to return to idle faster, but if there are the other mechanical issues mentioned above, the IAC decay won't help.
Old 03-07-2007, 02:40 PM
rubber duck's Avatar
Have you messed at all with the throttle body or put a new one on?
