Locked T-Top Cant unlock it now
Well I was seeing if i could lock my driver side t-top since i noticed when i got the car I couldnt lock the pass side.. well now I cant unlock it so I did the common sense thing grab some plyers, ya i twisted my keys 4 different ways so after i straightened it enough to unlock the doors i just said **** it for the day
wth guys? it locked just fine now its stuck
The following users liked this post:
Straight6chris (03-26-2023)
Originally Posted by Genesis_26317
Those suckers just popped open to, I couldn't believe it how easy it was.
It feels about the same on mine or not. When i got the car they were When i took out the the t-tops the handle had a little tension on it. I thought the tops seized up from sitting. Then i tried using the key it was about the same so i it back and continued to use them that way.
WOW I HAVENT SEEN THIS ONE YET
Originally Posted by GregD63
Try some WD-40 or motor oil on the key and lock. If that does not work, call a locksmith, and tell him you will bring the car to him. He should have a way to get the lock to turn. One of the little pins in the lock is probably just broken or stuck.
