rough idle, hesitation when accelerating
Old 05-07-2007, 11:21 AM
mulletwearingtadrive's Avatar
Default rough idle, hesitation when accelerating
Ok so my car has been acting up lately. It is idling really rough and will shake pretty bad at a stand still and at times when I accelerate it feels like the throttle is stuck for a few seconds. Like I will accelerate in first and it will hesitate and the car shakes, then if I stay on the gas for a few it will kick in and accelerate fine. Any ideas what might be causing this. I also have a misfire....was going to change my plugs and see if that solved the misfire.
Old 05-07-2007, 02:44 PM
bumpity
Old 05-07-2007, 02:52 PM
SSpdDmon's Avatar
If it's close to stock, I'd say MAF and NBO2's if you asked me to guess. A dirty MAF and lazy O2's will have those symptoms.
Old 05-07-2007, 03:26 PM
CAMAROZ28AQUINO's Avatar
i just fixed this problem in my car today....i had a bad missfire and had the same symptoms you described. I changed my two fron o2 sensors with bosch 13111 from a c5 corvette rear o2 sensor....you dont have to extend them and theyre supposed to be stronger...this fixed my problem instantly. I also had an insufficient activity bank 2 sensor 1 which is the passenger side...hope this helps
Old 05-07-2007, 04:46 PM
The car has longtubes, an offroad Y, catback and a few other bolt ons. MAF is stock GM but descreened...
Where did you get the C5 o2 sensors? how much?
Old 05-07-2007, 04:48 PM
Toes's Avatar
Have you checked your fuel pressure?
Old 05-07-2007, 05:31 PM
PhillyCamaro16's Avatar
Sounds fuel related because of the hesitation and than going okay. how many miles are on the car ?? Check fuel pump/filter/injectors. I don't think it's likely, but easy enough to check -- Plugs/Wires.
Throttle Stuck: Look over your throttle body, check and make sure the blade is opening and closing nicely as you rev the engine. Are you throwing and DTC's -- SES light on?
Old 05-07-2007, 06:03 PM
black01_WS6's Avatar
sounds exactly like a o2 problem. I would find someone with ls1edit, hp tuners, autotap or something else to see your o2 numbers first. If that isn't the culprit then I would look at the plugs, then fuel pump.
Also how long has it been since you changed your fuel filter?
Old 05-08-2007, 01:40 AM
The car has 103k miles.....I haven't changed the fuel filter before. Up until now the car has run really great the whole time I have had it, with minimal problems. I will see about a shop running ls1edit or something to check my 02 numbers. Would a hypertech work? I have one that I used to calibrate my speedometer when my gears were installed.....
Old 05-08-2007, 01:50 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I was gonna say cam is too big....wait. That is my problem.
Old 05-24-2007, 01:24 AM
would a hypertech work?
Old 05-24-2007, 01:43 PM
The SES light has been on since I installed the headers and offroad y pipe....
Old 05-24-2007, 02:00 PM
Stang's Bane's Avatar
try plugs and wires first. That sounded exactly like mine. plugs and wires fixed the problem!
Old 06-09-2007, 03:56 PM
i replaced all the plugs today and the problem is still there........ugh, I want to break something
Old 06-09-2007, 04:19 PM
z28poweredlt1's Avatar
Try replacing the wires, I'm having the same problem after h/c longtubes ory, ls6 intake swap, just replaced the intake gaskets and injector o-rings with no luck. Would be doing wires right now but no one has them local.
Old 06-09-2007, 04:23 PM
the wires are MSD superconductors, you think that could be it?
i am going to change the fuel filter and hopefully get someone to scan it and see what the o2s look like
Old 06-09-2007, 05:20 PM
najss's Avatar
Get someone to scan it and read the codes its the o2 sensors
Old 06-09-2007, 08:47 PM
yeah I had that done a couple hours ago and it is definitely the o2 sensors.
will be replacing those as soon as possible
Old 06-09-2007, 11:51 PM
Replaced my plug wires, car runs a lot smoother when it's not having this problem, unfortunatly the problem is only sometimes, so I'll have to replace the o2's with some others I got lying around, I'll let you know how that goes.
Old 06-10-2007, 10:34 AM
If you haven't bought the o2's yet get the corvette o2's sensors. the bosch ones, can't remember the part number off hand. They will work better with a long tube set up on our cars. they have a wider heat range than out stockers.
Quick Reply: rough idle, hesitation when accelerating
