Car puls to the right when step on the brakes
I know I need alignment because the car pulls to the right all the time, but sometimes when I step on the brakes it will pull real hard to the right (not all the time) is this part of the alignment issue or is there something wrong with my brakes? Thanks in advance
Pete
Pete
Pete
Pete
Does it pull at all after you apply the brakes, then release the brakes as you roll?
happened to me as well. i realized the caliper wasn't compressing rather it was just pushing further and further outward bc there was NO pad left. metal to metal! check your stuff fast. if it is the caliper you can get them at autozone.
Originally Posted by jdnz28
mine was pulling also , id check the air pressures in the fronts that was my problem.
x2 low air pressure and a little road crown will damn near the wheel out of your hand. Check the free/easy thing first.
Wow I sort of had the same problem I never thought about checking the brakes..
When I stop at a red light and roll up, my steering wheel would start pulling farrr to the left or farr to the right
