Headlight motors interchangable?
Can I use the one from the passenger side on the driver side? I'm thinking no, but my passenger one stop working all together, it used to stick up and down and i would have to turn the headlights on and off a bunch of times to get it to come down or up but now its doing nothing. I have an extra one but its from the drivers side. Thanks
That could be because the threads are stripped. If the fuses are good it should work. You can also disconnect the leads and check the circuit with a volt meter when you flip the switch.
Just try the free fix it only takes 5 minutes to do. It would eliminate stripped threads as a possiblity. The volt meter would eliminate the circuit. This would leave the motor. I would go to a junk yard or e-bay for a replacement. Good luck with this.
Originally Posted by GraphicNature
not to but in but how do you flip the headlight motor without taking the motor out my car has the grinding headlight sound coming from the driverside light thanks
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
