Spark plugs
Old 07-23-2007, 07:26 PM
2000Z28ls1's Avatar
Default Spark plugs
Im planning on doing my spark plugs within the next week wondering if anyone has a website that gives a good how to guide.Also any tips how to do it would be really help ful. And what is the recommend spark plug gap, I got NGK 55s if that matters
Old 07-23-2007, 07:45 PM
AFASTYZFR1's Avatar
http://www.installuniversity.com/ins...sity/index.htm
Old 07-23-2007, 07:46 PM
AFASTYZFR1's Avatar
Its under install documents.....has step by step with pics
Old 07-23-2007, 08:52 PM
2000Z28ls1's Avatar
Sweet thanks alot man.
Old 07-23-2007, 09:49 PM
MrEddie's Avatar
I did mine for the second time last week and it's much easier the second time (anti-seize used on the plugs). Oh, if you have a set of ramps, the #8 plug is the easiest to do from underneath. Also, you should remove the negative cable on the battery - someone posted a while ago that a wrench hit the starter and created quite an arc show.
Old 07-23-2007, 09:56 PM
2002_Z28_Six_Speed's Avatar
Remove the coil packs. Takes a max of 5 mins a side and saves you a huge amount of trouble and time later on.
Old 07-23-2007, 10:39 PM
sroach20's Avatar
do it with the engine out of the car. it took me like 5 minutes.
Old 07-23-2007, 11:10 PM
AutomagicLS1's Avatar
Or with the heads off sitting on a bench
Old 07-24-2007, 08:23 AM
JakeY2KZ's Avatar
Definitely take the coil packs off for more access. If it's your first time taking them off, it'll be a bitch. The back bolts are a pain to get out. Take your time. I believe it took me about an hour to do it my first time.
Get some LT's and when you put the coil's back on, only put the first 3 bolts back in.
Old 07-24-2007, 11:29 AM
2000Z28ls1's Avatar
so number 8 is easier underneath? My friend was telling me that but on Installuniversity they did them all from up top
Old 07-24-2007, 12:38 PM
Phoenix WS6's Avatar
I managed to do them all from the top, looked from underneath and it didn't look like it was gonna be possible. Getting it from up top was pretty easy with the coil pack rail off.
Old 07-24-2007, 12:58 PM
staringback05's Avatar
also one for this
Old 07-24-2007, 02:23 PM
Spurkey's Avatar
The InstallUniversity writeup talks about replacing the plug wires as well because "Your wires are not all that good either, that is why we are replacing them with a very good set." How do you pick a good set? I'm in Canada, I don't want to have to pay shipping/duty/tax/etc. just for plug wires, I'd like to find something locally.
Also, do the NGK iridium plugs make any difference? (The search was broken yesterday and today, some database error thing ) Lastly, would a swivel socket help, or one of those snazzy double-swivel sockets:
http://www.c5forum.com/diy/sparkplugs.php (Under #2)
Old 07-24-2007, 03:00 PM
sroach20's Avatar
if you remove the coil packs, do not put the very back bolts in when you reinstall. this way it will be easier the next time you have to remove them.
Old 07-25-2007, 09:50 PM
ghardester's Avatar
LS1Tech 10 Year
Plan for the whole day and remain calm. It will probably only take 3-4 hours the first time. Second time is a piece of cake. Be brave, stay calm. Have an extra vehicle available to run for new tools. It's fun.
Old 07-25-2007, 10:10 PM
2000Z28ls1's Avatar
I think im doing it friday hopefully if they come in the mail tomarrow im seafoaming my whole car and I hear it can foul plugs, I know the previous owner had it done so hopefully they used anti seize may make it alittle easyer Im hopin I have the craftsmen 150 peice set or something around there I bought a swivle socet a 10in extension I got elictrode silcone, anti seize I should be set but I got all you guys to help me out which EVERyone on here pretty much ROcks just wanted to thanks everyone whos helped me.
damn that was alot and im sure it isnt spelled right but if have any more questions Ill post up
Old 07-27-2007, 02:48 PM
2000Z28ls1's Avatar
Alright day is here Question can I tighten the plugs to much? I tightened them with a rachet lightly till it was pretty snug but the site says 1/4 past finger tight? so wondering if im gonna be alright I got drivers side done and I dont hear any noises
Old 07-27-2007, 03:42 PM
waiting2bl33d's Avatar
get an 1 and 1/2 or something like that extension makes everything easy i have never used a swivel on them.
Old 07-27-2007, 05:01 PM
2000Z28ls1's Avatar
Done seem to run fine accept the exaust leak from the AIR guess its a good excuse to order race headers!!
Quick Reply: Spark plugs
