Help About Power Steering Noise!!
About 3 days ago i noticed a weird sound coming from my steering wheel..
when i turn the steering wheel no noise come louder.. or when i accelarete it comes and after more acceleration it stops..
when i turn it left or right it sounds like when you go at Rear gear at high speed you hear a sound.. its like that.. i tried to add steering fluid of Shell but the sound starts 2 days later(today).
What can cause of that noise?
thanxxxxx
thanxxxxx
Originally Posted by pjb
is the fluid getting low and needing to be refilled?
i add it 2 days ago with shell steering oil and noise stops but it starts again today
how can you not be sure if the fluid is low or not, and needs refilling?
mine has that same noise, it leaks and it leaked on to my alternator and fucked up the electrical i had to buy a new battery and alternator. im actually putting the new one in today when i pick it up. but for your power steering problem i have no idea i just know mine has the same problem lol
My cars STEERING WHEEL FLUID IS LEAKING!! I AM SURE THAT WHEN the level is low steering wheel start to making Noise..
But my repairman said "Trans Ams Steering wheel system cant be REPAIRED, So you need you need to buy new one"!! Whatever! In my country there is no Steering part liek that And I need to buy from Jegs and it look expensive..
IS IT TRUE STEERING LEAKS CANT BE REPAIRED?????
Originally Posted by 67RSCamaroVette
i've had mine crack down by the o-ring where the reservoir goes into the pump, and it whined when the level got low. i found power steering fluid on the back of my car, and the whole underside. look closely for leaks, and top off fluid, it should be okay.
You explain my problem exactly. The fluid leaks.. that it whins.. It make me mad
hmm.. I checked under hood not under the car but I cant see exactly where the leaking come from
