Low Trac light during hard braking, but not sliding
Old 10-15-2007, 11:00 AM
HoLLo's Avatar
Default Low Trac light during hard braking, but not sliding
When I apply my brakes, sometimes not even hard at all, but usually it has to be a harder than usual stop. My Low Trac light will come on for a few seconds and go off. I am not sliding at all. Obviously its a sensor, but where is it? and how do you replace it?
Old 10-15-2007, 07:10 PM
Formula413's Avatar
That just means the abs system detected wheel lockup and engaged the abs. It's perfectly normal. The lockup could have been so brief that you didn't even feel it, maybe you hit a bump as you were braking and one wheel was unweighted enough that it skidded.
Old 10-15-2007, 09:07 PM
ae13291's Avatar
yup mine does it tooo, umm but wat if the trac control is off??
Old 10-15-2007, 09:51 PM
Formula413's Avatar
I think if TCS is off the Low Trac light will not come on for wheelspin but will still come on for wheel lockup.
Old 10-15-2007, 09:54 PM
conde'strans's Avatar
Mine started the same way but now does it every time I brake at a normal stop. I asked around and did a search turns up the front wheels have a sensor behind each which are causing this to occur. I was advised to clean them to see if it worked but nothin they still turn the low trac light on. I guess I will have to replace them eventually. There's your problem!
Old 10-16-2007, 06:00 PM
bzettler83's Avatar
could just be that your tires are worn and lock up easier.... both T/a I have had did that on hard braking nothign to be worried about...
Old 10-16-2007, 06:58 PM
HoLLo's Avatar
Well, i remember when my Firebird had some bald tires, it would slide, and it was VERY noticeable when it slipped. This does not slip, and the tires have more tread on the front than the ones my Firebird had
Old 10-16-2007, 09:55 PM
ae13291's Avatar
wait i dont hav a problem do i?? isent it normal!! i remember i had rear bald tires my car never slid, abs worked beautiful, i guess its normal to feel the pulsing in the brake pedal while abs is on right??
