LS1 overheats
Old 11-09-2007, 06:56 AM
dimitry's Avatar
Default LS1 overheats
I own 01 Trans am 6 speed.Recently my engine start overheating. Usually this happens when i drive over 30mph. I'm second owner and i don't have service history my car has 89,000 mile. I checked coolant level and it's ok.Is this could be coolant bad ? Since i think this is original coolant. Or maybe thermostat ?
I think i will flash antifreeze/coolant first. If issue remain same i guess change thermostat.
One more thing
temp would fluctuate... mainly getting hotter when i go faster and would cool right now in the snap of a fingers if i slow down. I keep RPMS low. Usually operational temp. is around 210. Recently it's 220-250.
Any other suggestions ?
Old 11-09-2007, 09:05 AM
Luder[PAK9]'s Avatar
Well, your coolant definately needs to be changed b/c Dexcool lasts 5 years (i.e. you're 1 year overdue).
What's weird is that teh car overheats only at highway speeds. I believe the radiator fans turn off at highway speed and turn on (when necessary) only at low speeds. Maybe that fact relates to your problem, but I don't know enough to offer any definitive advice.
Check your air dam--is it still there/intact? Also, check the front of your rad to see if any debris is blocking it. When I bout my car used, I found a cleaning wipe that had obviously been stuck to the rad for a couple of years.
Old 11-09-2007, 09:58 AM
Greggy's Avatar
Exactly, check for broken missing air dam and clogged rad.
Old 11-09-2007, 11:37 AM
2001NBMZ28's Avatar
Could be something as simple as a bad radiator cap - not holding pressure. Since the temp fluctuates as fast as snapping your fingers I'd also take a look at the ECT sensor connector/wiring.
Old 11-10-2007, 08:23 AM
dimitry's Avatar
Default oh
It's wired but now it's overheats on the lower speeds,So i guess speed doens't make difference. Is this could be sensor issue ?
Old 11-10-2007, 09:07 AM
2001NBMZ28's Avatar
Is the car actually overheating or just the gauge reading high/low? The gauge gets it's info from the ECT via the PCM.
Old 11-10-2007, 10:05 AM
buddha845's Avatar
had a similar problem and it turned out to be a bad head gasket. find someone to do a head gasket leak test to make sure theyre all squared away. kinda extreme but its always good to touch every base
Old 11-10-2007, 10:32 AM
SStockSuckS's Avatar
im having the same problem recently ... car overheats...hiting 250 yesterday so i had to pull over...
Old 11-10-2007, 01:11 PM
dimitry's Avatar
i went to service station we flashed radiator and changed antifreeze looks like issue resolved.
Old 11-10-2007, 01:33 PM
Black FormulaLs1's Avatar
would do a 160 stat anyways...
