how hard install on SLP fan switch?
Old 11-10-2007, 07:53 PM
motownZ's Avatar
Default how hard install on SLP fan switch?
just ordered one and when it get here i just want a idea what i have to do.. thanks
Old 11-10-2007, 08:36 PM
2001NBMZ28's Avatar
Install is easy and comes with directions - I ran the wire into the car through the grommet under the PCM - disconnect the battery before removing it.
Old 11-11-2007, 06:28 AM
camaroguy26's Avatar
like he said it is really simple. The hardest part is finding out where to mount the switch but I had a spot picked out for it before I started. When I did my M6 swap my center console didn't have an ashtray cover so I made a plate to cover it and have it mounted there. a really nice spot is on the driver's seat next to the seat controls, hidden and looks stock if done right. I ran it through that same grommet nbmz28 mentioned but I recommend using some rtv to seal it up nicely afterwards since I've had leakage problems when I ran my amp power wire through there.
Old 11-11-2007, 04:10 PM
motownZ's Avatar
thanks for the help. ill post soon as get it ,if any problems
Old 11-18-2007, 05:18 PM
motownZ's Avatar
well just got it. where did you ground it to? can i use a existing ground or do i have to make a new seperate ground for it by it self?
was going to use an extra oem swich but it has a 3 way switch. soo im guessing its not possibol.
Old 11-18-2007, 05:30 PM
2001NBMZ28's Avatar
Use the ground right by the connectors...remove the nut and put the eyelet from the switch on it...retighten...that's the only ground you need.
Old 11-18-2007, 05:32 PM
motownZ's Avatar
just wanted to make sure, the instructions seems to make a new one
thanks
Old 11-18-2007, 09:35 PM
letsrun97z's Avatar
i drilled a hole in my ashtray that way its hidden
Old 11-19-2007, 01:07 PM
Thumpin305's Avatar
Here's a picture of mine
I traced either a nickle or dime with a pencil to get the correct diameter hole the directions call for (measure them first). I then used a dremel to cut the hole out.
It's a very easy install and very straight forward. The switch really helps with engine temps during the summer.
Quick Reply: how hard install on SLP fan switch?
