Brake rotor removal
Old 11-26-2007, 05:45 PM
1FSTLS1's Avatar
Default Brake rotor removal
Any clever ideas on how to get my rear brake rotor off on my 81 Trans Am. I have been beating the crap out of it with a big hammer. I tried a tortch and every chemical that I have. The thing wont budge. Help
Old 11-27-2007, 12:13 AM
waldershrek's Avatar
Eat your Wheaties and get a bigger hammer. Trust me, I feel your pain. Seems like every time I do brakes the fockers won't budge but they always do eventually with a bigger hammer and the more pissed off I get.
Old 11-27-2007, 12:32 AM
Disturbed Bird's Avatar
release the parking brake. lol
Old 11-27-2007, 01:10 AM
minesfaster's Avatar
Are there bolts on the back side ?
Old 11-27-2007, 09:23 AM
1FSTLS1's Avatar
I have not got the other side started yet. What do you mean bolts on the back side? Just a normal rotor with wheel studs. The caliper holder bracket bolts to the axle housing. Mabe I could get a sledge hammer from my old man.
Old 11-27-2007, 09:53 AM
1998Z20what?'s Avatar
you must of not unbolted everything it shouldnt be that hard to pull it off once you removed the caliper. you said its a 81? maybe rust is giving you a problem? good luck
Old 11-27-2007, 03:27 PM
johnnydi's Avatar
Before you hit it too hard and break or bend somethinh else like your axle or wheel bearings, soak tel hell out of it front and back with WD-40. Tap the rotor all around in a circle front and back while you are spraying to help the WD-40 get between the rotor and the wheel hub. You might have to let it sit 15 minutes and do it a second time but it should work. It did for me.
John.
Old 11-27-2007, 03:29 PM
johnnydi's Avatar
Make sure you spray around the studs so it gets to the hub.
Old 11-27-2007, 03:37 PM
Mr Incredible's Avatar
Assuming you have the e-brake off, all the brake parts off, and it's just the rotor on the hub/studs, rust must have really taken hold!
I have a 3lb and a 4lb hammer for such occasions. You may need to shorten the handle some for tight areas. Start with taps and work your way up to major blows. Take your time, as each tap may be the one to break the rotor loose. After a while, though, call the rotor replaceable and commence to whackin'.
An important consideration is to use a piece of wood between the rotor and the hammer. It keeps the rotor usable until you really have to call the rotor dead and do what you gotta do to get it off.
Start tapping on the back on each side, then top/bottom. Repeat. Repeat some more.
If required alternate side/side and top/bottom with a star pattern like you tighten lug nuts.
Repeat the above while escalating the strength of the blows.
Again.
Somewhere in there the dang thing should have broken loose.
Once it's off, I'd use a powered wire wheel on the back of the rotor (if you're reusing it) and on the hub. I put a bit of anti-sieze on mating surfaces to keep the rust at bay.
In fact, rust and corrosion building up between rotor and hub or rotor and wheel are usually the cause of what most folks regard as warped rotors. Clean those surfaces off before you spend $$ on new rotors and see what happens.
Old 11-28-2007, 04:51 PM
1FSTLS1's Avatar
Got that bioch! Banged the studs out and that seemed to free it up. I broke by BFH and had to use a BFPW. Big Fn Pipe Wrench!
Old 11-29-2007, 01:35 PM
Yay!
Old 11-30-2007, 04:59 AM
johnnydi's Avatar
It's all cake from here!
