50,000 Mile Tune up?
I would check/change
Air filter, fuel filter, pcv valve, spark plugs, dif fluid, tranny fluid (filter if auto), oil filter, and def. run seafoam some of that might seem excessive for 50 k but the way I think is that it cant hurt and if you take care of your car it will take care of you
i would also grease ball joint and that stuff change power steering fluid maybe change u joint's also check you motor and tranny mounts for where or dmg
Some people claim that you shouldnt on high millage tranny's b/c they say the old fluid and sludge in the tranny and filter help hold the seals together or something but its a bunch of BS. But I have heard that VW has some kinda new tranny out where its pretty much a sealed unit and your not suppost to touch it for 100k.
If you go to www.installuniversity.com and look at the install docs for 160 degree thermostat change.To drain is steps 1-4. Steps 12-17 explain how to refill your coolant system.
