Headlight Motor
Old 04-24-2008, 01:51 PM
blackw66's Avatar
Question Headlight Motor
Yesterday,after going to lunch,when I turned my headlights off there was a strange sound from the driver side headlight..like the motor was still running.it does this for maybe 10 seconds then stops...
Any clues??
Thanks
Old 04-24-2008, 02:22 PM
1badragtop's Avatar
Needs new headlight motor for drivers side or replacing headlight gear - I dont recommend just the gear though. Try search for headlight motor concern, there's a lot of info on here for it.
Old 04-24-2008, 09:30 PM
2SLOWT/A4NOW's Avatar
The gear is stripped. Only part of the gear is used however. What this means is that you have half the gear still unused. Take the linkage off the motor and then turn the manual **** untill the shaft that the linkage is attached to rotates 180 degrees and reattach the linkage. Or get a new motor or replace the gear. If you elect to replace the motor, spend the dough and get a new OE motor from the dealer. I have tried several remans and replaced several gears and the torque of the motor has always tore the gear cover off in a short time. Maybe I'm just using the wrong epoxe.
Old 04-25-2008, 01:43 AM
needadvice's Avatar
holy moses, how can this not be a sticky already
scroll almost to the bottom "FREE headlight fix".
http://www.bfranker.badz28.com/headlightfix/index.htm
Old 04-29-2008, 12:24 PM
blackw66's Avatar
Thanks for all the help.
.Life is fast at times ,but on
LS1TECH...LIfe is Fastest.with answers
Old 04-29-2008, 12:47 PM
lonala's Avatar
Autozone now sells headlight motors $70
Old 07-09-2008, 10:18 AM
5301113's Avatar
Those motors don't last as long as the stock ones and they have a limited warrant. The gears is always the problem. Replace the gears and thats it.Save your money for something better.http://www.fquick.com/videos/Install...ight_Gear/2024
Old 07-10-2008, 12:31 AM
Copy & Paste Moderator
VIP1's Avatar
IT IS A STICKY! .... and in multiple sections!
Sticky:
General Maintenance & Repairs FAQ -- PLEASE READ BEFORE STARTING THREAD
https://ls1tech.com/forums/general-maintenance-repairs/929492-general-maintenance-repairs-faq-please-read-before-starting-thread.html
The specific topic:
Firebird Headlight Noise Or Odd Behavior
https://ls1tech.com/forums/showpost....7&postcount=16
Old 07-10-2008, 01:30 PM
needadvice's Avatar
Sticky:
https://ls1tech.com/forums/showthread.php?t=929492
The specific topic:
Yeah, but its quite obvious that sticky's are useless, noone reads them and they never will.
Old 07-10-2008, 02:07 PM
Danny2tek's Avatar
Read my sticky!!!
Old 07-10-2008, 11:55 PM
VIP1's Avatar
..... says the one who said it needs to be a sticky when it already is
Old 07-11-2008, 11:53 PM
lt1noob's Avatar
no its not the motor its a stripped headlight gear. mine does it too, i would suggest replacing it with a set of metal ones because i just replaced mine and 2 weeks later it stripped again. the dealership will tell you its the whole motor but its only the gear that strips and a plastic oem replacement will run you about 15-20$
Old 07-14-2008, 03:42 PM
5301113's Avatar
I got one a O’Reily’s auto parts for $12.00 even cheaper
Old 07-14-2008, 04:20 PM
bboyferal's Avatar
How do you know they do not last as long? Proof?
Old 07-14-2008, 04:26 PM
5301113's Avatar
I know ppl dont like hearing this but my friend went threw 2 motors in 1 years. Of course i dont have paper proof or pics or whatever proof you need but i help my friend with the replacing the motors. so thats my proof.Last time we did the gears replacement ,it's fast, easier and still working 2 years later. I rather do the less expensive fix first then finding out the hard way and replace whole motor when the problem is the gear not the motor. I learned from his mistakes
Old 07-14-2008, 07:10 PM
bboyferal's Avatar
The reason I'm asking is because I'm running remanufactured motors, and they've lasted me longer than the stock ones so far...
Of course, these are not Autozone ones though... Don't know anything about those.
I thought Autozone just started selling these?
Old 07-14-2008, 08:30 PM
needadvice's Avatar
Nobody reading them no matter where or how many times they are posted is what has now made it "quite obvious" they are useless...and always will be.
Old 07-15-2008, 12:42 PM
5301113's Avatar
OOOOOHHHH i see what your saying. You have had good experiance with the remanufactured ones. i guess auto zone ones are different
Peace
Old 07-15-2008, 04:49 PM
98 WS6's Avatar
My stock gear was stripped, so I replaced it with a metal one. Two weeks later, my motor was, and still is, completely dead. No noise, no motor turning, nothing.
Quick Reply: Headlight Motor
