Y-pipe banging
Old 05-11-2008, 06:34 AM
SSquid's Avatar
Default Y-pipe banging
I got hooker longtubes and hooker ORY... it came with those clamps... so its clamped on around 2k-3k... it bangs against something... LOUD... if I weld them instead of clamps will that help?
Old 05-11-2008, 08:22 AM
OIF1VET's Avatar
I had some exhaust banging under my car(Y pipe hitting driveshaft safety loop).. Simple fix for me was wrapping those areas with header wrap and a couple clamps.. Took care of all my banging sounds..
Old 05-11-2008, 06:26 PM
SSquid's Avatar
Does anyone know the size of the Hooker Y pipe? 2.5 or 3.0? I think I am gonna try the bumpstop from Thunderracing.com first? will I be able to put that on by jackin up the car myself? also do I need 1 or 2???
Old 05-11-2008, 08:07 PM
95 Z28's Avatar
You can try that bumpstop. Do you have poly motor mounts?
Old 05-11-2008, 08:26 PM
98WsSick's Avatar
it's probably banging on the floor board put a piece of rubber heater hose between the y pipe and the floor board it worked for me
Old 05-12-2008, 12:20 PM
Mr. Brett's Avatar
^^^ Same here. I had that problem with my Pacesetter Y-pipe so I just put some high-temp heater hose in between the pipe and the floorboard. You can feel it in the shifter, but at least it doesn't bang. And it's only a temporary fix until I replace the factory engine mounts with something more solid...
Old 05-12-2008, 05:39 PM
SSquid's Avatar
I am gonna do the bump stops... do I need 1 or 2?
Old 05-13-2008, 04:09 AM
SSquid's Avatar
?????.....ttt
Old 05-13-2008, 06:42 AM
Thorny's Avatar
The bumpstop was a waste of money for me, I had to put in poly motor mounts which solved the problem 100%
Old 05-13-2008, 07:29 AM
Johns00Z28's Avatar
Mine was banging often so we put spacers on the crossmember where it was banging but when my car is on an incline it still bangs. Not sure what to do.
Old 05-13-2008, 08:58 AM
tylerdj's Avatar
Heater hose will give you a quick temporary fix. I put poly motor mounts in mine to get rid of it.
Old 05-13-2008, 10:45 AM
Johns00Z28's Avatar
Do the motor mounts bring the motor down a bit and therefore prevent it from hitting the floorboard?
Old 05-13-2008, 11:41 AM
95 Z28's Avatar
They're not as "flimsy" as the stock rubber ones, so they hold the engine in place better. That's all. You reuse the stock metal clamshell that goes around the mount. Drill out the rivets in the shell, pop out the rubber stockers, put in the poly's, bolt it back together. Mine work great.
Old 05-13-2008, 11:47 AM
Johns00Z28's Avatar
So the motor mounts being flimsy is causing everything to move and bang into the floorboard?
Old 05-13-2008, 11:54 AM
Mr. Brett's Avatar
Correct.
Old 05-13-2008, 03:42 PM
SSquid's Avatar
not one of you have answered my question weather I need 1 or 2....
Old 05-13-2008, 03:46 PM
robertbartsch's Avatar
A poly transmission mount was the trick for me. ...cheap and effective.
The banging drove me crazy (no pun intended)!
Old 05-13-2008, 04:13 PM
Mr. Brett's Avatar
Every person I've ever talked to who used that bump stop said it worked for **** and ended up just using some rubber hose and/or installing stiffer motor mounts....
Old 05-13-2008, 04:32 PM
Motor mount replacement is not easy or cheap. A poly transmission mount is cheap, way easy, and effective for the y-pipe bang issue.
Old 05-13-2008, 04:51 PM
Thorny's Avatar
I did them one at a time. I did the drivers side first and it worked real well for a couple of weeks, then it started banging again under hard acceleration. After I put the other one on the problem was totally fixed. They are NOT fun to install, but there are worse things you could be doing.
Quick Reply: Y-pipe banging
