extendind AC lines???
Old 06-11-2008, 07:38 PM
presto_z's Avatar
Default extendind AC lines???
i moved my radiator and AC condenser vertical to make more room for my turbo setup, but now my upper AC line is about 2" to short..
can a new section be soldered in to make it longer??
Old 06-11-2008, 07:53 PM
AKAFRED's Avatar
you would have to tig weld a section in there.. i have done 2 ac systems like this now... works mint.
Old 06-11-2008, 07:55 PM
presto_z's Avatar
damn. i was hoping soldering would work lol.. looks like i will be taking it down to have it extended 2 inches
thanks
-steve
Old 06-11-2008, 08:08 PM
2002_Z28_Six_Speed's Avatar
Get another stock tube and then use two unions to join them That would be easy and will work well.
Old 06-11-2008, 08:16 PM
9000th01ss's Avatar
No, take it to a shop that specializes in automotive AC work.
They will most likely have a catalog with a list of fittings that are designed to have rubber hose crimped to them.
Don't get your hopes up, that line has the orifice tube in it right where it bolts to the evap, that fitting to hose might be a problem to find.
Old 06-12-2008, 05:17 PM
AKAFRED's Avatar
just cut and weld... unions may leak..
Old 06-12-2008, 06:04 PM
NO OFFENSE AT ALL.
Never had one do that. Used on AC, brakes, ect. You may wish to have someone watch you install one or use a better quality part.
I mean why trust the factory slip fit that is already there? Take your AC apart and you know what one I am talking about. Or a nitrous flared fitting? I think those are worse than unions.
Old 06-12-2008, 10:00 PM
9000th01ss's Avatar
I have a custom system in my truck with two aluminum tubes joined by a brass flare union and single flares. Four years no problems. (knock on wood )
Old 06-16-2008, 07:44 PM
AKAFRED's Avatar
flare union should be ok.. just dont use the cheap unions with the brass ring.. they arent rated to 200+ psi
