Evap Purge Valve
Old 07-01-2008, 04:34 AM
Crimsonnaire's Avatar
Default Evap Purge Valve
Do any of your purge valves have a 5mm play at the ends? Is it supposed to fully tight?
When I checked this valve on another TA, it was completely tight with absolutely no play. In the bottom pic, the distance between the yellow ring cap on the intake end and the illuminated ring directly above is the available space that the piece is able to slide in and out (about half a cm).
Old 07-06-2008, 04:39 PM
CCF1000's Avatar
You know i was wondering the same thing mine looks like urs and i think it should be flush but idk.
Old 07-06-2008, 06:57 PM
You can feel a looseness on the ends of your plastic tube as well? Have you gotten any evap leak codes?
Old 07-06-2008, 07:27 PM
CCF1000's Avatar
I think so but i haven't had any codes come up yet. There is something weird going on with my car so im gonna autotap it eventually it still doesn't feel right still seems like it has a misfire.
Old 07-06-2008, 08:11 PM
Do you have rough idling? I read that if you have misfires when driving, you'll get a flashing check engine light...
Old 07-06-2008, 09:53 PM
2002_Z28_Six_Speed's Avatar
It should be a lil loose. This shouldn't cause drivibility problems.
Old 07-06-2008, 10:18 PM
nemss1's Avatar
delete ur evap. solves problems of connections and breaking canister. its for emissions crap anyways
Old 11-05-2008, 02:04 PM
ss.slp.ls1's Avatar
So there is no operational side effects of deleting the Evap?
Quick Reply: Evap Purge Valve
