tough/hard blinker?
Old 08-02-2008, 10:21 AM
futuref-body's Avatar
Question tough/hard blinker?
I have a 2000 ws6 and i live with my brother in law who has a 2002. one day i finally got to drive his beast and didnt think anything but then when i got back into my car-i noticed that the blinker was tougher than his to get to "lock in". so is this maybe a new one after the factory blinker messed up? or is there maybe a screw or something i could loosen? not a big deal just one small detail to make my car that much better
Old 08-02-2008, 11:15 AM
cool whip's Avatar
I noticed my '99 has a pretty tough blinker to operate as well. It seems that way in every pre-'01 GM I've driven. Okay, I don't have to do warm up reps before changing lanes, but I can operate the turn signal in my Toyota 4runner w/ one finger. If there's a cheap and easy way to remedy this I'd be interested as well.
Old 08-02-2008, 11:20 AM
samson_420's Avatar
Same here. My 98 blinker sucks mad *****.
It comes down to - Is it worth to use my blinker this time?
Old 08-02-2008, 12:25 PM
SparkyJJO's Avatar
My 98 isn't that hard to operate. It isn't a smooth motion, feels like it came out of an 80s pickup, but it is functional and I can use just my finger to operate it if I want.
Old 08-02-2008, 12:28 PM
IronOutlaw's Avatar
i got pissed and pushed on my blinker switch too hard and it fell off.
Old 08-02-2008, 01:51 PM
samson_420's Avatar
That's why I am at the point of not using it.
Old 08-03-2008, 12:12 PM
Save the manuals!
wssix99's Avatar
Yes - solved this on my '99. I assume you all are talking about the turn signal switch mechanism, right?
If so, its just a lubrication problem on the switching mechanism. A slight pain in the *** to fix, but well worth it. You have to pull the air bag and steering wheel. If you have done this before, its about a one-hour job. The main pain for me was that the F-Body steering wheel requires a special bolt for the steering wheel puller, which you won't get in a "regular" puller kit. (You need an enhanced tool kit or to hunt down special bolts.) Its also important not to drive the puller bolts too far in to the wheel as they will damage the interior mechanism.
Basically, you have to take off the airbag, steering wheel, and lock plate to get to the turn signal mechanism in the steering column. Once in there, you need to liberally lubricate between all of the moving plastic and metal pieces with white lithium grease. Afterward, it should be as good as new.
If you go in, you may also want to replace the two switch return springs. These tend to break after a 100-150K miles and just cost a buck or so at the parts store. Its definitely worth not having to having to risk pulling the mechanism again in a couple months if one goes out under normal wear and tear.
Old 08-03-2008, 10:18 PM
samson_420's Avatar
I rather just not use my blinkers.
Old 08-05-2008, 11:23 PM
yungepjr's Avatar
Default blinkers? fuse?
my turning signals wont work. i replaced the fuse once, it worked for a good 5 minutes. then stopped working. replaced it again and same thing. any1 kno wats wrong??? everything else works fine all my lights. except my right fog light but thats jus tha bulbs out. but how do i fix this? cops are already ******* with me over no license plate so i need to fix these blinkers.
Old 08-06-2008, 07:50 AM
Save the manuals!
wssix99's Avatar
Read this first: Probably flasher? https://ls1tech.com/forums/showpost....18&postcount=7
Old 08-06-2008, 08:41 AM
xBROKEx's Avatar
mine only works on one side, i think the mechanism is broken
Old 08-06-2008, 10:05 PM
Save the manuals!
wssix99's Avatar
The switch or the lights?
Old 08-06-2008, 11:31 PM
yungepjr's Avatar
both. The switch moves up and down but the lights dont blink or anything
Old 08-07-2008, 07:38 AM
Save the manuals!
wssix99's Avatar
If your switch "clicks" the contacts are being made and the switch is probably fine. If your hazards work and both side blinkers don't, you just need a new flasher. Just do a search - lots of posts on this site on those issues and how to find/replace the flasher.
Old 11-17-2008, 07:05 AM
patchz28's Avatar
I was wondering this myself. I have a 95 and was thinking that I would have to replace the column or something. Ill try to lubricate it and see if this solves my problem!
Old 11-19-2008, 10:16 PM
Bret's WS6's Avatar
Back when I had my 94 Trans Am I complained to my dad about this same problem. He said, "Son, that's a man's car, get used to it."
