idler pully
idler pully
Where can i buy the idler pully for the ac? Im looking every where and there charging like 60 or like 80 bucks because there coming with a tensioner which the pully i need doesnt have a tensoner its the top one for the ac. where on earth can i buy one for a ls1?
I looked on there site and the one im looking for i cant seem to find the only one i can find is for the side for the power steering and stuff not the one for the a/c side.
The 2 idler pulleys for the a/c are the same size. They are different then the idler pulley for the main belt. I just ordered 2 from sdpc. 12557335 is the part number for just the pulley's . I couldnt find them at any parts store.
I had problems finding them for a while.. I found them to be the same size on both upper and lower. They are not the same as the many belt and pulleys, since the main belt is a 7 rib and the AC is 5 (?). They are also smooth and not ribbed.
They can be found a most auto chain stores as well as the dealers. There AC Delco numbers, Four Season and other. I am at work and will post the part numbers that I used when I get home and look at the invoice.
i went on there site to check it out just says pully no picture no detail on which pully it is. kind of dont wanna buy another one like i did from napa and it be wrong.
