Header Install Help
Header Install Help
Today i started the process of installing my headers on my 99 z28...and at the point of just removing the air tubes, egr, and coil packs. I was just wondering how people removed the last bolt on the coil pack on the passenger side. I can't even see it and there is minimal space to get a ratchet back there. I was wondering what other people did to remove that last bolt.
use a 10mm i think is the size gearwrench and it should be fairly easy. some people dont install that last bolt when they reinstall the coil packs so they dont have to fool with it anymore lol.
i do use a ractheting wrench but i guess you just gotta try harder. i kind of didn't try to hard because it was cold outside but i was just wondering what other people did.
X2
Just left them on
I don't know if the 99 set up is different from my 01, but I loosened all the manifold bolts from up top except the back one on the passenger side, then took the Cat off and had a wide open path to it It was tight to get that one started once the headers were in but if I can get my fat *** arm and xlarge hands in there I would think most everyone else can get it
Jman
Just left them on
Jman
an endwrench or ratcheting wrech and time is all i can say...i had a friend with long skinny arms too and he helped a lot lol DO NOT reinstall it! you probably need two of those bolts to hold that bracket on so leaving one off will hurt nothing. i can take my coil brackets off in like 10 mins now and it makes getting to the back header bolts so much easier i dont know how some of you left them on there...
