Header Install Problem
Old 11-25-2008, 03:45 PM
Sunryze88's Avatar
Default Header Install Problem
I went to install my headers today and everything was a breeze until i got to actually putting my headers on....I got all the bolts but two on the passenger side and i think they are cross threaded or whatever because i can't get a bolt in there far enough... so i got tap m8 x 1.25 and got it trying to thread but it snapped but i got it out of the block so not much a problem...should i just try the tap again? has anybody had this problem? any other solutions?
Old 11-25-2008, 04:59 PM
Raise's Avatar
Did you reuse the stock bolts or the ones that came with your headers? What kind of headers did you get anyway?
Old 11-25-2008, 06:09 PM
Closed ex-Sponsor Account
Tom@ARH's Avatar
Not sure which headers system you bought but I think everyone still retains the use of the stock bolts
Old 11-25-2008, 07:35 PM
bichin95redta's Avatar
I've installed my share of headers on 4th Gen F-Bodies. Two things I've found to be VERY helpful with the install:
1. get a thread-chasing (cleaning) tap, and "recondition" all exhaust manifold bolt holes
2. this is just my opinion, and opinions are like elbows.....most folks have at least two...anyway, I have found ARP header STUDS far easier to use, and far less likely to damage threaded holes, than either aftermarket, or reused OEM bolts
But that's just me.......
Old 11-25-2008, 08:14 PM
jsteele90's Avatar
factory bolts worked everytime for me. the pacesetter bolts that came with my headers looked really cheap
Old 11-26-2008, 03:42 PM
Sunryze88's Avatar
I got the pacesetters and tried reusing the stock but then tried the ones that came with the headers...i think i got them threaded pretty good now i used a tap and i can hand thread much better than before i think still might have to further i didn't try to go to far in because i didnt want the tap breaking in there.
Old 11-30-2008, 05:09 PM
raysz28's Avatar
any tips on getting the original manifold bolts out? im installing pacesetter headers and have everything but the factory manifolds off. anyone have trouble with shearing off header bolts? i just dont want to have to drill out or re-tap anything lol...more work than i want to do.
Old 11-30-2008, 06:47 PM
vsocks1's Avatar
Haven't heard of too many troubles here...I know I didn't have them with mine!
