Direct Hits ignition
Re: Direct Hits ignition
Since no one has an answer for you, I'll give my opinion. I believe the factory ignition system is so powerful, that gains from an aftermarket booster of any type will be pretty much non-existent.
BMW ///M Nerd
Agreeable, using spark plugs, is tried and true + cheaper! A good set of NGK plugs, and some MSD wires will do the trick just fine. Our ignition system truly is awesome, you really don't have to upgrade much at all, even on a high horsepower motor in my oppinion. Just wires and plugs will do you fine.
Off topic...but I notice that you are in the AF and in Utah. I had the EXTREME misfortune of being stationed at Hill for 2 years, 3 months, 15 days and 6 hours. Where are you at on base (I was 729th).
Hows the car scene out there these days? There wasn't much happening when I was there. Ever do any street racing out there?
Thanks all for your answers...
I'm with the 649th Combat Logistics Support Squadron... Been here for a while as my children live with my ex here, thus I am here to stay...
I use to drag race in Washington state... Did some solo racing here with another car i use to have. There is a lot of race action as well as car shows here. I am not racing now as I'm busy with a lot of other stuff, but on occassion get an anoyance next to me wanting to race and I let her rip...these cars are fast...but I want faster...thus I am trying to improve it any way I can.
Does the LS1 ignition system use multiple sparks or long duration spark at lower revs?
Does anyone know where I can get some in depth information on the DIS used on the GEN III motors?
As for the original question you really only gain peak HP from an ignition system if your current system is lacking. Most modern DIS systems are extremely powerful-in some cases several times more powerful than the older HEI systems.
Multiple sparks and long duration sparks can have some benefits in the lower RPM range and can improve idle quality.
I use this system on both of my 8.1 trucks. I found the throttle response to be a little better and I did note that the mileage improved in each truck. My C5 will be getting this system along with a few other mods next week
Tom
Tom
