Dynomouth Soundclips?
I need some Dynomouth sound clips. I will be getting it soon and wanna hear it. I heard it in person, and have been in a car with dynomouth and it was incredible. Just wanna hear a rev, drive by, and WOT or anything else you have Thanks.
Re: Dynomouth Soundclips?
Holy crap, give me every clip you have!!!!
That was awesome!!!
Do you think it will sound that good on an automatic?
Thanks to your video I think I might just get Loudmouth and when I get headers, cam..etc. I'll put in the bullit.
That was awesome!!!
Thanks man! And that wasn't even full throttle, I didn't have enough traction on the salt. I'm sure you won't be sorry with a LM. Yeah it should sound the same on an automatic, or maybe a little deeper since automatics tend to keep the rpms lower. Keep in mind though I have a cam (TR224,) that improves the sound also. But I see you plan to get a cam anyway.
If you don't plan to get a cam eventually,then you shouldn't be on this site! Or at least this area of LS1tech.
I am still in High School, so major mods on a Warranty motor are out. I need to keep the car drivable so I don't blow anything up. I was told by ALQ4 that I sholdn't do anything major till I can aford to fix whatever breaks so a cam will wait. I will just do bolt-ons, and a higher stall on the T/C and then when the time comes comes cam and ported heads. Then, maybe, a nice supercharger.
You could put in a small to medium sized "supercharger friendly" cam without changing the reliability or driveabilty of your car. That wouldn't lead to breaking or blowing up anything unless installed improperly. Most cams aren't a problem anyway unless you go too extreme with lift and ramps. True, warranty would be out the window, but I doubt you will need that anyway if everything is good with your engine now, unless you are planning on taking it back for oil consumption. Another option would be to put in an LS6 or Hot Cam; since those are GM cams many dealerships will agree to not void the warranty, especially if they install it for you.
Here's another, not mine though. He doesn't have cats with his.
http://home.kc.rr.com/soundengineer/Car/Exhaust/SLP.mp3
