Code and ASR after intake swap
Hey guys,
I just swapped to a BBK intake on a 2002 Camaro and after getting everything buttoned back up I threw code P0107 and my ASR is not working. Are both these things related to a bad MAP sensor? I noticed while putting the sensor into the back of the intake that the rubber seal had a tear in it.
Also, is there any easier way to replace this sensor other than removing the intake?
Thanks for any help.
According to www.obd-codes.com
CausesThe causes of a low MAP sensor signal circuit (P0107) could be any of the following:
Bad MAP sensor
Open or short in the signal circuit
Open or short in the 5 Volt reference circuit
Ground circuit open or shorted
Bad PCM
Bad MAP sensor
Bad PCM
Bad MAP sensor
Bad PCM
Bad MAP sensor
Bad PCM
I have big hands so its pretty tough. Even after pulling the coils do you think there would be enough room to work on the plug if there is something wrong with it? I don't know why they made the thing so damn short.
