Help major exhaust leak!!!!!
Old 07-22-2009, 07:49 PM
camaro_ss_97's Avatar
Exclamation Help major exhaust leak!!!!!
Ok here it is i have stainless headers on my camaro and i kept hearing an exhaust leam and finally found it at the flange on all 4 ports its leaking exhaust out the top of the flange and i changed the gasket out and it is loose towards the top of the flangs its not seating good at the top what do i need to do?????????????
Old 07-22-2009, 08:26 PM
crainholio's Avatar
Remove the y-pipe from that header, so you can tighten that header to the head without the y-pipe putting it in a bind.
Then fight the y-pipe onto the header collector after it's torqued properly.
Old 07-22-2009, 08:47 PM
Well i had my exhaust welded up so the only thing i could do it to cut it and then get it re-welded right?
Old 07-22-2009, 08:50 PM
crainholio's Avatar
Is it welded directly to the header collector? Never seen that done, usually there's a clamp or bolts.
Old 07-22-2009, 08:54 PM
Yea it is the shop i took it to wanted to do it that way said it would be better i had sure seal clamps to put on
Old 07-22-2009, 08:56 PM
crainholio's Avatar
Might better take it back to the shop, sounds like the header wasn't properly installed at the time they welded it.
Old 07-22-2009, 08:58 PM
DaddySS's Avatar
Either that or bend the y pipe apart slightly to allow the header to rest flush to the head.
Old 07-22-2009, 09:04 PM
Both good ideas it may be easiest for me to cut it and tourqe it up and then re-weld it
Old 07-22-2009, 11:34 PM
shaun's Avatar
my y and headers are all welded also i kept having leaks from my tsp y so i got pissed and welded it all together and guess what the leak was still there so i know its coming from one of the header gaskets and i used new gm ones so i think im going to cut it and try and fix the leak then use a but joint band clamp and it that dont seal ill just reweld it.
Old 07-26-2009, 07:11 PM
do you think that a copper header gasket would seal up better?
Old 07-26-2009, 07:24 PM
crainholio's Avatar
If you have a gap between the flange and the head, you could use 100% pure Depleted Uranium header gaskets and they wouldn't seal.
Old 07-26-2009, 07:29 PM
i have never heard of those where would i get them
Old 07-26-2009, 08:18 PM
crainholio's Avatar
It's possible you missed my point...
Old 07-26-2009, 08:42 PM
oh yea lol i did not read it right before
Quick Reply: Help major exhaust leak!!!!!
