Trying to install my 92mm FAST & nothing but problems
Old 07-30-2009, 08:53 PM
Ksths2's Avatar
Default Trying to install my 92mm FAST & nothing but problems
To make a long story short my 8 grey stock rubber intake seals off my LS6 intake are rectangle shaped and my new 92 FAST intake are square corners on the bottom but has a round top. So my grey seals are too big and they don't fit...So i was going to order the FAST red #54009-8 seals but the picture of them look like my stock ones that are rectangle........any help with this?????
Also, i ordered a Speed inc. GTO/Corvette fuel rail fitting install kit and i'm completely confused how i'm supposed to plumb my Speed inc. fuel rails since my fire wall won't let the fittings work.....
Old 07-30-2009, 09:12 PM
JFM-jr's Avatar
Your better off with a fresh set of FAST gaskets anyway. The FAST gaskets are actually a bit thicker and will provide a better seal and the price (25 bucks) cant be beat. Cant help with the fuel rail problem sorry.
Old 07-30-2009, 09:54 PM
Ksths2's Avatar
i agree about the sealing of the new seals but i'm worried about the shape of the seal. the recess in the intake looks like the "cathedral" shape more than a rectangle and i'm just worried that the FAST seals won't fit this shape since they look to be rectangular rather than rounded at the top or closest to the injector...... does that make sense?
Old 07-30-2009, 10:08 PM
ICRAZY6's Avatar
It does, was the Fast intake new? When I got mine it already had the seals installed. I would make sure when ordering the fast seals to specify that they will fit the Fast 92. That's about all the help I can give you. Good luck
Old 07-30-2009, 10:16 PM
Ksths2's Avatar
Yep brand new & thats weird cuz my instructions even say it comes with new seals and mine didn't....... great....
JFM-jr's Avatar
The FAST 90/92's are only made for cathedral ports. The gaskets are rectangular and will be correct for your intake.
Old 07-30-2009, 10:28 PM
fly pantera's Avatar
I went to speed inc site and saw the felpro,so instead of waiting for them I just went to local parts store and they had some felpros for the ls6.yes mine were rounded like yours.I tried mine from my stock ls6 to see if they would fit but they would not,i guess they were stretched out to much.ones from local parts store worked fine and has no leaks.
Old 07-30-2009, 10:29 PM
mine was brand new and did not come with seals either
Old 07-30-2009, 10:54 PM
C_B64's Avatar
yeah, they don't come with seals new.... Mine didn't..... And the rectangular seals are the correct ones........ If you need some fast and dont wanna wait, they sell fel-pro intake gaskets at Advance, autozone, and o'reillys
Old 07-31-2009, 05:29 AM
JFM-jr's Avatar
I read the grooves in the FAST intake that the gaskets sit in are cut deeper than an OEM one. Thats why the FAST gaskets are a bit thicker to provide a better seal. I am not 100% on this info maybe somebody else can chime in here.
Old 07-31-2009, 10:21 AM
SweetS10V8's Avatar
I don't know what instructions you have, you must have misread something maybe??
My intake didn't come with intake gaskets, and it even says so in the instructions. You can also see on page 7 that its not listed anywhere in the "included parts" section.
