coolent crossover tube?
Go to the dealer. Get two crossover tubes and don't block the back ones off off.. Unless you want to. It would be cheaper to do that, but I believe it's better to have coolant flowing through through the back as well. Goodluck!
i got my crossover from gmpartdirect and had a shop cuz and weld the little numbs on the back to make my own block offs, just ganna make sure they tig weld it wit aluminum filler, i got it done for free, good luck!
this was all because they sent me some bolt instead of the actually block offs
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788
here--->https://ls1tech.com/forums/general-m...t-numbers.html
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478
