Header install check list
I am going to be ordering everything i need and wanted to be sure i have everything. I have searched and read the stickys but want everything correct.
1- pacesetter longtubes
2- tsp catted y
3- o2 extensions
4- plugs,not sure which ngk's i need. stock ls1
5-need to send my computer in for a mail order tune. get the rear 02's knocked out
6-motor mounts - where is a good place to purchase these? Looks like a major PITA but is worth it
also a good step by step write up would be good but havent found one yet.
thanks in adavance
2- tsp catted y
3- o2 extensions
thanks in adavance
List looks good. tr-55 are the plugs you would want. stock heat range and all that stuff.
Here is a site for the motormounts if you would like.
http://www.ws6project.com/user_stor/...oducts_id=1490
there are a couple write ups out there just google it.
good luck!
good luck!
good luck!
good luck!
Thanks alot..will be ordering them up
yeah like a tiny 10mm ratchet wrench... it is your best friend for the passenger side header bolts. There is NO room back there what so ever. A friend is also recommended. It helps to have an extra hand if needed.
As was said might as well replace the head gaskets if they are stock. I'd clean the header bolts off real good or buy some new ones. A lot of mine got fussy haha. 10 mm ratchet wrench is a freaken savior, i couldn't do without one.
Pcms are normally sent out the morning after I receive it.. and normally takes 2-4 days for you to receive it after its sent!
If you have anymore questions don't be afraid to ask!
Blaine
again thanks alot guys!
Ok so i will bait a few friends over to have a couple tall boys and make thim work.. ok i will check out my local sears tommorow to see if i can find a 10 mm ratchet wrench
The parts store in my area carries factory type exhaust manifold gaskets "fel-pro" would these be adequate or should i source from a gm dealership?
Thanks alot! I will probably fill the form out and said it out early next week,is the car ok to drive after even if the headers arent installed yet or is it better to wait untill after the install?
