hooking up DMH a cut-out with OUT the wire harness?
Old 05-26-2010, 11:59 PM
D.Jones's Avatar
Default hooking up DMH a cut-out with OUT the wire harness?
ok, just bought a DMH cut out used from a friend for a good deal, but he didn't have a wire harness or switch to go with it. I tried emailing DMH Performance to see if I could purchase just the wire harness but no response yet so thinking of going over to the local radioshack and/or auto parts store and rigging one up. My question is, would this work properly (wont damage the function of the motor) and what would be the easiest way to do this? thanks
Old 05-27-2010, 03:08 AM
kmracer's Avatar
how many prongs/connections are there?
Old 05-27-2010, 06:11 AM
blades11b's Avatar
grab a rocker switch some test leads and a test light and verify your terminals with a battery for function and wire it in.. too easy
Old 05-27-2010, 05:40 PM
D.Jones's Avatar
it has two prongs.
thanks, ill give that a try
Old 05-27-2010, 06:51 PM
Hard Core Z28's Avatar
What a shock DMH not responding to customers.
Old 06-01-2010, 10:50 AM
D.Jones's Avatar
Ok bought a rocker switch and some wire, how would I hook this up? There are two wires coming from the cut out, one black and one white. And there are 3 prongs coming off of the switch, a power, the accessory, and the negative. Sorry, but I suck at wiring things up lol
And if the rocker switch is just a simple on/off switch, how does this open and close the cut out? Thanks again.
Old 06-01-2010, 10:51 AM
D.Jones's Avatar
Old 06-01-2010, 02:26 PM
KirkEvil's Avatar
Quick Reply: hooking up DMH a cut-out with OUT the wire harness?
