What is the name of this piece?!
Old 07-18-2010, 09:28 PM
CHRRRIS's Avatar
Default What is the name of this piece?!
I changed my oil today and while I was under there I noticed this piece, however mine does not have a bolt or that weird blue thing in it... It actually appears to have a bunch of gunk and debris in it, and it may be leaking around it's gasket. Need to know what it is so I can get a new one and hopefully stop the leak!
Old 07-19-2010, 12:33 AM
Duffster's Avatar
It's the location to tap for aftermarket oil pressure gauges or re-directing oil flow for something else. . .
Don't know the name, but give me a minute and I'll check the parts catalog...
Can't find the name, but I can tell you the one that comes on the car isn't tapped normally, but you can do that easily. I had mine tapped for a while and filled it in. more info can be found here...
http://www.nastyz28.com/forum/showthread.php?t=155034
D
Old 07-19-2010, 08:32 AM
thunderstruck507's Avatar
you don't need a new one, just pull it off and run it over a file to get a flat mounting surface and put it on with a new gasket and very very light film of rtv silicone
I tapped mine for the chevelle's factory oil pressure warning light
Old 07-19-2010, 11:21 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Please tell us you're NOT using a Fram filter of any style!!
Old 07-19-2010, 12:57 PM
LS1MCSS's Avatar
If you have a bolt missing, that's why it's leaking. Just get a bolt for it and you'll be fine.
Old 07-19-2010, 04:02 PM
CHRRRIS's Avatar
No I'm not using a Fram filter LOL that's not my picture, I found it on google.
Anyways, thunderstruck that might be what I go ahead and do. But where do I get a gasket when I don't even know what the piece is called?!
LS1MCSS, If you look at the thread someone linked above, it sounds like the hole in it isn't even tapped, so I don't think it comes with a bolt in it from the factory... it's almost like a breather or something...
Old 07-19-2010, 04:08 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
OIL PAN COVER - 12577903 - 8.04
GASKET - 12611384 - 3.55
Both on hand.
Old 07-19-2010, 04:29 PM
CHRRRIS's Avatar
^ That's it! Thanks. I'm going to check the area around it again in about a week or so since I cleaned it up while I was down there so I can actually see if it's leaking or not.
If it's in fact leaking I'll send you a PM!
Old 07-19-2010, 04:45 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Great. No prob.
Old 07-19-2010, 08:40 PM
Closed ex-Sponsor Account
PartsTaxi.com's Avatar
We would be glad to help you with these parts as well, and guarantee our price to be cheaper then any other GM dealer.
Thanks
Kevin
www.PartsTaxi.com
Old 08-03-2010, 12:42 PM
CHRRRIS's Avatar
Since I think this is leaking, I should probably drain the oil before I remove it, correct? Only reason I ask is because it looks like it sits above the oil level.
Quick Reply: What is the name of this piece?!
