TSP Cats
It hangs lower b/c your probably used to seeing the stock flattened pipe in there and now your looking at a full 3" pipe that takes up way more room than the old.
One day when I have time, I think I might add an exhaust hanger somewhere around the merge to hold the y-pipe up a little bit more.
Short shifter.
I might be completely off here, but I thought most "high-flow" cats flowed pretty close to OEM honeycomb cats? The "high flow" thing was, at least the impression I was under, in comparison to the old pellet/bead style catalytic converters. I know the aftermarket ones are typically smaller, weigh less, tuck better, etc, but I'm curious as to whether anyone's done any empirical testing on an OEM and an aftermarket cat.
