broken header bolt in head. What would you do?
Old 08-26-2010, 02:10 PM
caseypryan's Avatar
Default broken header bolt in head. What would you do?
the header bolt right by cylinder number 1 (very front driver side bolt) broke. Do I have to take the head off or can I fix it with the heads still entact?
Old 08-26-2010, 03:35 PM
Jon@Texas-Speed's Avatar
It depends where it broke at. You can typically drill them or use an "easy-out" and get them out. Just depends what tools you have available. Typically on that cylinder, you can get them out in the car. If it is real stubborn you might have to pull it off though.
Jon
Old 08-26-2010, 05:02 PM
caseypryan's Avatar
Thanks john. Yeah it seems like I couldn't get tools in right there and my arsenal is very limited... I was thinking I might as well just pull them off and put some 243's on and do a cam. I try to find opportunity in every thing I break on my car haha
Old 08-26-2010, 05:07 PM
haha... I hear ya man. I'm the same way. I built a motor once over an exhaust leak.
Old 08-27-2010, 12:54 AM
SSmoken's Avatar
this happened to me. i just bought new heads lol.
Old 08-27-2010, 01:05 AM
Squirts11's Avatar
Lol. Agreed.
Old 08-27-2010, 06:21 AM
Steve Gunn's Avatar
Don't buy a cheap easy out. I broke off a harbor freight one inside of what was left of the bolt. What a bitch. I had to dremmel around it with a tiny bit, drill it out and then use a helicoil. But hey, it worked!
Old 08-27-2010, 01:22 PM
caseypryan's Avatar
did you have the head out when you did this? or all in the car? I can't get a drill in there to get it out..
Old 08-27-2010, 01:59 PM
SS4Luck's Avatar
i had this happen to me once and thanksfully there was just enough of the broken edge hanging out of the head that i could lock onto it with some vice grips and turn it out
Old 08-27-2010, 07:17 PM
Steve Gunn's Avatar
My bad, I did it out. Power steering and ABS in the way? Maybe you can float stuff out of the way or get a right angle drill?
Old 08-27-2010, 08:42 PM
Mtrhd329's Avatar
I did that before on the rear bolt on the drivers side head....a bitch to get to. Took it off in about 15 minutes and took it to the first machine shop that was open (it was christmas morning) and had a guy drill it out and retap it for me for 10 dollars. He even gave me the next size up bolt for the hole he made. Might be worth a call before you break an easy out in there and have to take it to a shop anyways!
