headers vs manifolds
need a little help here and hopefully I put it in the correct area.
have a '04 LQ4 in my wheelin rig. it has a mild cam and car intake (truck intake would not fit under the hood) and everything is stock that I know of (cept painless marine comp and harness)
my question(s) is this...... should I keep the stock manifolds or go to block hugger headers. I do not have room for long tubes and don't want to spend the time or possible expense of making some that would work.
not sure if the headers would be worth the couple hundred bucks and are the cheaper headers (like the hooker headers on summits website) good enough?
TIA
TIA
The stock F-body manifolds flow pretty good for stock and I know on the 3rd gen swaps most say to just use the stock manifolds unless you are putting on long tubes. There is not a huge gain to be had when swapping to shorties from what I have gathered, but others may have another opinion.
See if there are any tri y doug thorleys for the ls1. They are a tad longer than shortys but major torque gains to be had with them. Idk for your application but that would be the best performance header before long tubes
seems the tri-y stuff is more than I want to spend at this moment, but thanks. just to clarify, I'm not trying to find the magic bean that creates tons of HP for cheap. just looking to see if an inexpensive set of headers will help a little more with the cam (and also getting rid of the manifolds)
anyone know if LS1 headers are a direct bolt-on for the LQ4?
after looking at what room I have, something that hangs down a little less might be better for d-shaft clearance and stay closer to the floor boards
thanks again
thanks again
not enough for LTs since it's all custom suspension on a rockcrawler
