ARH ory ?
ARH ory ?
Did any of you have to remove your tunnel brace after you installed your ARH/ORY. Mine seem to hang kinda low . I tried to space down the brace with washers but it still hits the exhaust and I'm always hiting it on the ground at driveways and speed bumps and stuff. I hate to remove it because my car is a vert and needs all the help it can get for stiffness but its rattling on the exhaust and scraping the ground all the time. Driving me nuts.
i had a problem with my ARH ORY hanging to low, did you try bending the exhaust bracket that attaches to the y pipe?...i put a swivel jack on the merge in the y pipe and pushed it up as far as i could then took a rubber mallet and beat the bracket up until it held the y pipe up higher... it worked for me no more rattling
I'm just going to get a a different tunnel brace. Mine is a spohn tubular if I find somthing flat it will save me an inch and a half maybee it won't scrape.
