How to make your own LS1 coil relocation brackets???
Old 03-10-2011, 08:50 AM
red281gt's Avatar
Default How to make your own LS1 coil relocation brackets???
I know this has been brought up thousands of times , I have seen a couple pics , but I haven't seen someone say how to make them. Like what u need in order for them to work. Where to get the wires. I seen dopefedz post of pics of his set up and looks clean as hell , but I think he don't have a/c in that thing .... I really don't want to spend 200+ bucks on something that looks so easy to do just need a push in the right direction. Thanks in advance .
Old 03-10-2011, 10:00 AM
Randy WS6's Avatar
You can go to any hardware store and get about every thing you need to do this, Its been a while since i done mine, I got a piece of 1/8" all thread and aluminum tubing with a 3/16" I.D. or hole and then take your coils off the bracket and stack them , Cut the 1/8" all thread to the desired length and then cut the tubing to space the coils apart were they don't touch each other, There is hole in the coils for the all tread to go threw, then put a 1/8" nut and lock washer to tie it all together, Then i took a piece of 1/8" aluminum and made a plate and drilled two hole in it to bolt the coils to it with the all thread that i used to tie the coil together. That was the easy part was making the brackets, the bitch was shorting the coil harness by cutting and soldering to wires together and heat shrinking , You will have more time in the harness than the coil brackets 10 to 1 .. Sorry i dont have any pics and wish i could explain it better, but hope this will give you a idea how to do it and maybe some one else will help you on here
Old 03-10-2011, 10:35 AM
red281gt's Avatar
That sounds good to me , maybe someone else can come in also with some pics .. but thanks that's some good info there
Old 03-10-2011, 11:07 AM
Pocket's Avatar
A few feet of angle iron, a welder and some bolts. Stock wires, 12" coil extension
Built for function, not aesthetics. Valve cover area was taken up by something more important
Old 03-10-2011, 11:14 AM
red281gt's Avatar
But I have a/c. I was looking at it this morning....
Old 03-10-2011, 11:18 AM
Pocket's Avatar
Its also in a 3rd gen
Use your head, you're asking about building your own kit, so take the ideas presented and figure something out
red281gt's Avatar
Something like this , I know that company makes them but I have a.c so those up there won't work. But I need to make mine like these ...
Old 03-10-2011, 11:20 AM
red281gt's Avatar
But I got it now , just would have to figure out the harness and wires ... thanks man , I had seen some of ur old post when I googled it
Old 03-10-2011, 11:38 AM
Randy WS6's Avatar
The way that i done my harness was to remove the harness from the bracket and connect all the coils to the harness plugs, and mark each one to its number cylinder , like #1 cylinder with #1 coil and so on, because the harness plugs are unique to the cylinder it fires on. Then strip the tape that covering all the wires and then separate each set of wire to each coil , they are color coded, Do one coil at a time , Do this after you have the coil mounted to the bracket that you made, to get the correct length, Now get you a soldering knife or gun and heat shrink tubing . Cut each wire to your desired length and solder the wires back together and dont forget to put the heat shrink on first, After the wire is soldered together take a heat gun or lighter and shrink the tubing to the wire, then complete the rest of the coil plug, There's one coil .After you complete one set (4) coils retape the harness and your done with that side. This is not hard just time consuming
Old 03-10-2011, 12:12 PM
Randy WS6's Avatar
Mine had AC, and mine fit . I found a pic of my engine ,you might see them lol...
Old 03-10-2011, 01:40 PM
red281gt's Avatar
Randy did u buy that kit? Or made it urself ? .... yeah I know that works cause u have it under the cowl . But look atthere set up is right next to the headers or what ever ... the a/c lines run there in the 4th gens ... was wondering what kind of plug wires did u use....
Old 03-10-2011, 02:05 PM
Randy WS6's Avatar
The wire are a MSD 8.5 universal (cut to fit) went to summit racing and ordered the Optic spark ends for the coils , I believe there the same as the LT1 with the distributor on the front of the crank shaft
Old 03-10-2011, 04:10 PM
red281gt's Avatar
Cool cool , ill pic some up this week end , going to do the brackets on sat then .. ill post pics when done.
Old 03-23-2011, 11:19 AM
530sx's Avatar
hey to threadjack a little, can anyone tell me, when relocating the coils do they need to be grounded? meaning does the bracket they get bolted into act as a ground? I'm in the middle of a custom LS1 project and was wondering if I could simply bolt them onto some 3/8" Acrilic plate I have sitting around. but wasn't sure if that'd invite trouble.
Old 03-23-2011, 12:59 PM
Pocket's Avatar
The harness connector already has a ground. Mount them to whatever you want
Old 03-23-2011, 07:10 PM
chrs1313's Avatar
wow now that's what I call alot of lines...looks good though
Old 03-24-2011, 10:48 PM
5.7mmImportkilla's Avatar
Man, thats a cool looking engine!
Old 03-24-2011, 11:07 PM
Randy WS6's Avatar
Thanks, Ive tried to clean it up some but its hard to do, I guess people will notice all the hoses and lines were there braided and all the colored fittings ,I have around 500.00 in hoses and fittings under the hood . Sense i took the pic, Ive removed all the AC and heater hoses and rewired under the hood. Getting ready to pull it, to put my new LS3 431cid in.
Quick Reply: How to make your own LS1 coil relocation brackets???
