What to do with extra vac/AIR hose running to lid? 2000-2002 guys!?
How do I block off this extra hose? Just run a breather over it and push it aside? What size is the hose? Anyone have a P/N for a breather they used? How important is that line that it is kept clean and in fresh air? Any help would be great! I am making my own intake for a 2002 Z28 with an otherwise stock engine.
if deleted ,you can cap off plug the left side valve cover.remove the hose completely.don't use a breather cap ,keep the engine sealed and add a oil catch can and repair the remaining PCV system.
Gary, thanks for the response. Since I don't have access to the tuner, is it ok to just pop a breather on it? What purpose does it even serve? Also, what size breather should I look for? Or what diameter hose is it?
